alfaboy
stopping smoking
Evening guys, I need some advice on welders as I'm going to be buying one shortly.
I have used a mig welder for 15 years in my previous job, mainly welding box section table frames in mild steel which I were fairly good at. The welder was a mono mig 151 with gas.
I need a welder for home use, not working on cars but craft stuff, bits of plate, chain etc and not sure what to go for, stick welder from machine mart or there's a wolf 140 gas / no gas set up on eBay for £170 delivered, this is a 40 - 140 amp mig with the small gas bottles.
That's the max of my budget so what's your advice, stick or mig!? Any info is much appreciated. Cheers. Daz.
I have an idea for a unique alfa. . . . and i think it might just work.
awoo
never heard anyone say those small gas bottles are good, they run out quickly and are expensive. i would go stick personally.
If its just big stuff then stick - obviously no good if you want to do car stuff . I would look out for a old Oxford arc welder, big oil filled things that will weld all day and don't go wrong
alfaboy
stopping smoking
What is the minimum thickness a cheap stick welder will work with?
Maybe 2mm , warping is going to be a issue . If you want to do thinner stuff as well i would look for a 180amp mig that goes down to 30amp . Plenty of poke for stuff and will go down enough for car work .
Problem is your budget - perhaps you could find a Clarke 180 for that secondhand if your lucky
Don't bother wasting your time or money with disposable bottles, they are pricey and last for minutes if used in anger.
alfaboy
stopping smoking
Sorted it, got a 30 - 135 amp mig and a full size bottle kit on order, bit more than I should spend but figure its a long term buy so why not ? Thanks for the info guys, much appreciated.
I think that will struggle with anything much thicker than a couple of mm
You could always buy a cheapy stick welder from Aldi/ Lidl when they are on special as well for welding thick stuff, do you welds on arty things need to be strong/ pretty or is it just a case of holding things together?
Some welding could be classed as art on its own in my view
smurf
Aldi mig welders will burs a 2.5mm rod or 2 then the thermal cutout kicks in
25 mins later you can burn half a rod, then the same thing happens
don't waste your money on one mate
Laser cutting and cnc punching (up to 3mm stainless and ali, up to 6mm mild steel)
Mail me a dxf file and i'll get you a price Metal folding and custom fabrication service also available
Had an aldi stick welder myself for 3 years or so, but never had a single problem. Welded numerous exhausts and patched bodywork with it. Sold it once i got a mig and got my 40 quid back. I'm not saying they're the best or anything but i didnt have any problems with mine.
at200
Mar 26, 2016 20:06:34 GMT
I would check out the mig welding forum for advice and info. www.mig-welding.co.uk/forum/If you register with Machine Mart you will get offers through - usually 10 or 20% off Clarke products.
