logicaluk
Help This is my 84 accaim, that ive been meaning to put up a build thread about, but never got arround to. Anyway, ive got to take the trailing arm off to finish up the welding but the bolt is seized in to the bush sleeve normaly id just cut straight through the bush but its a good bush and its made of unobtainium so i cant repace it. Ive been soaking it in penetrating oil for sevral days but i don't think its getting into the sleeve ive had the windy gun on it but it doesn't do owt as the bush takes the impact out and ive tryed wedging the sleeve so it doesn't rotate but thats not worked, a big bar only rotates it and i don't want to tear the bush up. Now I'm out of ideas. Any suggestions would be greatfull attempted. Dan
Last Edit: Mar 5, 2016 11:51:06 GMT by logicaluk
if you've turned the bolt already its torn the bush off the sleeve so needs replacing anyway.
logicaluk
It only rotates about 1/16 of aturn then springs back
Last Edit: Mar 5, 2016 14:37:22 GMT by logicaluk
Can you get at both sides of the bolt?
logicaluk
Nope its a captive nut under the lump in the inner cill, I don't really want to hack in to the inner cills as they are really solid, but i may have to. Cheers Dan
Last Edit: Mar 5, 2016 14:46:14 GMT by logicaluk
andyborris
logicaluk
Thanks andy, but unfortunately or not depending how you look at it the suspension was one of the things triumph improved when the got hold of the civic. And that bush is quite different. Cheers Dan
andyborris
Sorry, only other thing I can suggest is, take the car of the stands and back on the floor, get some large mates to sit in the boot, (to add weight) and try the windy gun again.
If the bush is in tension, it may not absorb the impacts.....?
I think you'll end up going into the cills anyway, that captive will fail......sorry!
Hi, From what the OP says the captive nut is not the problem. The bolt is turning but only a little bit because it is seized in the sleeve in the bush. I think the bolt needs to be cut off either side of the bush/sleeve, the arm can then be removed and the bolt drifted out of the sleeve.
Colin
You could try heating the head of the bolt, if not cut it off either side of the bush or drill it out.
If you can get a drill down the middle of the bolt from one end then the heat may spread and loosen it. start with a small bit and go as deep as you can then try to turn it. If that fails go to the next size up in the drill box, rinse and repeat, sooner or later one of two things is going to happen, its going to come out or your going to drill it out. Just make sure the first one goes in straight.
1988 DUTTON LEGERRA MK1 - SPARES DONOR 1989 DUTTON LEGERRA MK2 - CURRENT PROJECT 1990 DUTTON LEGERRA ZS MK2 1990 DUTTON LEGERRA ZS MK2 DUTTON PHAETON S2 - Resting DUTTON PHAETON S4 - Resting DUTTON PHAETON S4 - PROJECT X DUTTON SIERRA S2 - Resting
take a very thin saw blade and cut the bolt on top and under the bushing, takes a while. That way the bushing is saved or is the bolt from unobtanium also ?
logicaluk
Cheers guys i think its going to be heat next, chatting with a mate last night about it hes got access to an inductive heater, if we can heat it and get out quickly i might just save the bush. Fingers crossed Dan
bolt seized in bushingChasR
@chasr
Club Retro Rides Member 170
I think you will have to lose the bushes unfortunately and take to them with an airsaw. I do know SuperFlex sell universal bushes which may be better than nothing in this application .
Try some penetrating fluid first like PlusGas or freeze spray. The bushing probably has a metal sleve inside which the bolt will have rusted too. The 1/16th turn will just be the give in the bushing getting taken up.
Heat might cause the metal sleeve to come away from the bushing which would make it even harder to get out!
I would go with drilling it out if you absolutely have to save the bush - cut or grind the head off to save time and resign yourself to having to open up the sill to replace the captive nut, the bolt should be fairly easy to replace with one of the same or higher spec.
logicaluk
Ive been trying to soak it in oxim ultra which ive had exelent results with in the past but i don't think its getting to the sleeve, I might try some freeze spray befor getting it hot.
bortaf
What about a rust dissolver? rather than trying to penitrate the rust disolve it? be a pig to get it stay on there though maybe a rag soaked in it around the bush to let it soak it and start to work? citric acid or vinegar It may be kinder on the rubber than heat?
R.I.P photobucket
logicaluk
Thats what the oxim stuff dose disolve rust, exept it sugar based by the smell of it. Dan
