Bedford Bambi Camper Van
I bought this a few years ago and started working on it but then moved away from Norfolk so it has been sitting at my inlaws place since then.
It was last on the road in 2012 and has 97k on the clock but the previous owner spent £1400 on the engine in 2010 and didn't use it much after that.
Now it needs two front arch panels and a new fuel tank fitting which is included (used). It fired up and ran with no problems when i had it but i did not get the time to start it up when i was home last weekend.
The front piece of trim missing in the photo is present. I just took it off as i did a little welding behind it. Apart from the welding mentioned above i think the rest is ok.
Inside it could do with a refit. But that is the fun bit right?!
It is located in Bracon Ash and will obviously need a trailer to take it away but it will fit on a standard car trailer.
