£300 And now on EBAY
A chance to grab a retro TKM Kart with a brand new 200cc honda clone engine, goes like the clappers and is great fun if you've got the urge to compete in racing but don't have all the cash
The chassis has it's battle scars but honestly is completely solid all the way over, very much needs a repaint or powder coat to get it looking like new.
Geared more so towards the lighter driver, still pushed my massive weight around just fine and goes rather quick! should be good up to around 45/50 mph. All bearings have been thoroughly cleaned and re packed with grease.
Replaced the missing master cylinder and made a linkage. Works a treat.
The engine is a 200cc honda 6.5hp clone engine that's' had less than 1 hours use. starts up super easy and has had the governor overridden by the throttle cable so i didn't have to crack the engine open and spoil the factory seal.
Straight axle at the back makes low speed cornering a bit tricky if you're heavier but at speed it's very grippy and hugely responsive.
Comes with a couple of spare carbs and a spare 160cc engine that was originally on the kart
I'm looking for offers around the £300 mark but come and take a look if You're nearby and make an offer/take it for a spin etc...
Will fit in the back of a clio/106 by the way!
www.ebay.co.uk/itm/-/322165746833?
