jpsmit
Aug 11, 2017 18:13:36 GMT
Just being entirely silly - referring to the pinholes in the laquer in post 866. Typically my brain goes in odd directions. :-) However, once you start running down the slippery slope labelled weight reduction it is difficult to control your speed and easy to go too fast and crash. I have to contantly apply the brake :-) I am sure it is neverending - and potentially problematic - i recall seeing a documentary which referenced Colin Chapman adding lightness to the point that his race cars were dangerous to the drivers. On a lighter note every time I view this thread I always here the Beatles singing "now they know how many holes it takes to fill the Albert Hall." Great work.
classicallybroke
If it doesn't look broken its probably not mine!
Aug 12, 2017 19:18:53 GMT
The last time I had this much fun looking at pictures it had tube.com at the end of it, Ace build mate a real forerunner.
Aug 14, 2017 10:31:55 GMT
The last time I had this much fun looking at pictures it had tube.com at the end of it, Ace build mate a real forerunner. But there have been more F Ups on this build than in any *tube.com video :-)
Aug 17, 2017 20:50:45 GMT
Fitted air intake pipe this morning.
Aug 20, 2017 22:24:35 GMT
Last Edit: Aug 20, 2017 22:25:36 GMT by nalesutol
jamesd1972
Club RR Member Number: 40
Are they glued in once profiled ? Does the stiffening bar pick up on the suspension at the front then? Still coming on well- list getting smaller or keep finding little things to add ? James
Are they glued in once profiled ? Does the stiffening bar pick up on the suspension at the front then? Still coming on well- list getting smaller or keep finding little things to add ? James Hi James All 5 (two on bar and three on carbon) are glued on. Not this bar. It runs between the rollbars that run down the A pillars and is also connected to the central spine of the chassis. The car is ready for wiring but, as you say, keep finding jobs not thought of but the list must be geting shorter.
Aug 21, 2017 21:43:48 GMT
Heat shields coming along. £160 of ZircoFlex III self adhesive heat reflective goodness.
Last Edit: Aug 21, 2017 21:46:12 GMT by nalesutol
Aug 24, 2017 22:39:33 GMT
tristanh
Routinely bewildered
Aug 25, 2017 16:17:50 GMT
Super tidy as always.
Sept 2, 2017 22:51:45 GMT
Making heat shields to fit into spaces that aren't really there is a PITA. Had to make a mock up first then make the real one. This one shields the alternator and wastegate actuator from exhaust and turbo heat. The hot side will be covered, as all shields will be, with ZircoFlex III.
Last Edit: Sept 2, 2017 23:07:29 GMT by nalesutol
jamesd1972
Shiny ! Booked in for wiring yet - give a nice date to aim for ? Nice work as always, one question if I may, what are you doing about paint work ? My vote is nothing at all but it counts for nothing ! Thanks for the updates James
Yup, I am taking the car to DC Electronics on Friday so they can see what they are up against, sort out what they will do and give me a price.
I have considered the rat look :-) However, it will probably end up satin grey or black. Safe, unassuming, colours.
Last Edit: Sept 3, 2017 20:06:59 GMT by nalesutol
jamesd1972
So ready for fire up soon ! Bet I'm not alone in being excited at the thought of that. Many thanks for the updates and replies to daft questions James
Yeah, scary :-)
No question is daft if you don't know the answer.
Sept 4, 2017 13:01:45 GMT
As race fire suits are heavy, uncomfortable and expensive, I decided to make my own out of aluminium and ZircoFlex. To that end I have started on the leg sections. Based on medieval armour, it will be light and articulated, allowing enough movement to be able to get in and out of car with very little help.
Sept 4, 2017 18:28:13 GMT
Looks more like parts of a Battle Star Galactica Cylon.
tristanh
Sept 4, 2017 22:38:28 GMT
As race fire suits are heavy, uncomfortable and expensive, I decided to make my own out of aluminium and ZircoFlex. To that end I have started on the leg sections. Based on medieval armour, it will be light and articulated, allowing enough movement to be able to get in and out of car with very little help. Like this... Lol
Sept 6, 2017 23:17:08 GMT
After a trial fitting I have decided that making my own firesuit isn't going to work. However, in order not to waste the parts already made I have repurposed them into exhaust shields. A little bit of VHT wrinkle paint and you wouldn't know their original purpose. Not the best wrinkling in the world but it has tidied them up a tad. I haven't wrinkled the shield sections that are under the exhaust.
Last Edit: Sept 6, 2017 23:17:47 GMT by nalesutol
Sept 7, 2017 19:01:03 GMT
Last Edit: Sept 7, 2017 22:44:24 GMT by nalesutol
