Nathan
Club RR Member Number: 1
DCOE 45 WOENathan
@bgtmidget7476
Club Retro Rides Member 1
Hi Guys
I have just had a DCOE fitted to my other car a 74 roadster, now originally the car was fitted with the standard carbs and sounded perfect with only small tapet noise. Now i have had this fittered and tuned professionally the ticking noise seems to be louder.
my first thought was the inlet not being tight enough but this seems fint so does the exhaust its a new manifold both in and out, i was just wondering is this normal i know with a dcoe there is no padding between the carb and exhaust manifold due to no heat shield, could this of been dampering the noise
just a bit worrying as the end sounded fine before this was installed the place where i got it tuned are classic car tuners so i would of thought that this would of been checked and they would of told me if there was an issue
many thanks
nathan
Are you sure it's not just the sound of the Weber? The jets make a lot of noise - bit like a taping noise.
Does the taping continue if you put the clutch in?
Nathan
DCOE 45 WOENathan
@bgtmidget7476
i have not tried that mate should it go when the clitch is in, would sound like your right then if they are noisey
Well - if it goes when you put the clutch in, it could either be the clutch release bearing or the idle gear! If it doesn't then it could be a whole host of things! But as it's just appeared after fitting the DCOE I would suggest that it's just the jets making a lot of noise - quite normal, mine are really noisey! If it was something serious then the guys who tuned it would have said something anyway.
Nathan
DCOE 45 WOENathan
@bgtmidget7476
sounds about right then mate as it was as quiet as a mouse well for a B series and she has been fine since the rebuild only 500 miles ago.
right will check the clutch but this was replaced 2k ago seems as though it is the dcoe
You'll get used to the noise. What filter have you got on it?
Nathan
DCOE 45 WOENathan
@bgtmidget7476
Nov 12, 2004 10:11:15 GMT
Cheaky grin just then, aint got one on it, sounds nice without but was going to run it and see of course curse word may get sucked in, hopefully not a bolt, was looking at Pipercross, what would you recommend
Nov 12, 2004 10:19:50 GMT
I gather you've got some ram pipes on at the moment then? You can keep those and get some of the mesh covers for the end to stop things getting sucked in! The problem with just ram pipes is that you can get to much air in when the engines cold.
I use a K&N with 1.5 inch ram pipes inside. I've always been advised not to use foam filters, but a lot of other people will say different.
Are you running a choke on it?
Nathan
DCOE 45 WOENathan
@bgtmidget7476
Nov 12, 2004 10:44:28 GMT
i see, nope no choke just twice hit on the pedal and boom she starts, tested it this morining after leaving her outside in the cold and was fine first time.
Nov 12, 2004 15:18:55 GMT
I had a pair of 40's on a ford 1760 crossflow in a Westfield. I ran trumpets with mesh covers even though the carbs were very close to the ground in that. No problems at all. manual choke as well. The induction noise was fantastic! Lots of chirping and clattering. It's just the carbs. Enjoy!
Peugeot 307sw - Suzuki SV650S - MX5.
Nathan
DCOE 45 WOENathan
@bgtmidget7476
cool thats a worry off my mind cus its soounded as if the tappets were really loose or the exhaust manidold coming away and both seem to be fine. the car runs nice with it much better than the SU,s on b4.
