sonus
Feb 14, 2016 18:51:15 GMT
I am considering using some AN-hoses as a vacuum hose from the inlet manifold to remote brake servo. The hoses are rated 500 psi for oil and water, but will they work for cm vacuum? On seller said they will the other didn't want to speculate.
Any advice?
Reason for wanting to use the AN-hose is due to the braided cotton outer.
Feb 14, 2016 18:53:44 GMT
sonus
Feb 14, 2016 18:59:36 GMT
Not looking for brake hoses, but vacuum hoses from inlet manifold to brake servo
Feb 14, 2016 20:17:49 GMT
Its probably not something they are tested for to be honest, they may well be fine - but then again they may collapse - do you know what the internal strengthening structure is? Is it not possible to get the correct vacuum rated hose and add a braided cover?
hario
S202 C300STD
Feb 29, 2016 16:46:19 GMT
*S202 C300TD Wagon* Installed: OM606 & 722.6, Evo6 IC, S600AMG callipers & 345mm rotors. No catz. Leatherish seats.. Rust.. Future: DIY manifolds & turbo compound build. Built IP, & some kind of software. Less rust..
Ryannn
Feb 29, 2016 18:39:46 GMT
The psi rating is for an outwards pressure and you want an inwards one. For want of a better phrase! Lol
What car is it for? It's such a common item now that surely there's a standard replacement?
sonus
Feb 29, 2016 21:28:17 GMT
It is for my TVR Vixen with remote brake servo.
Kieran
Feb 29, 2016 21:56:43 GMT
You are not talking a massive or full vacuum.
Most hose (ie fuel hose) will be fine.
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
sonus
hario
S202 C300STD
The psi rating is for an outwards pressure and you want an inwards one. For want of a better phrase! Lol What car is it for? It's such a common item now that surely there's a standard replacement? Atmospheric pressure is 15psi max so it has to be rated to at least that, the plastic pneumatic hose is fine, I've used it loads of times.
