johnd
Jan 26, 2016 19:44:26 GMT
I'm fitting them to my kadett, banded of course
I have a full set of 4x100 13s but am using a 4ha rear axle so have bought two in 4x114 14"
I quite like the idea of bigger rears but would also like 14" front in 4x100....
Do they exist?
MonzaPhil
Think like a man of action, act like a man of thought
Jan 26, 2016 19:51:03 GMT
Not as far as I know. Vauxhall use 5x120 for 14 inch Rostyles.
You may have to use adaptors.
This is now a clicky linky!
johnd
Jan 26, 2016 19:52:06 GMT
Be too wide for adaptors
MonzaPhil
Jan 26, 2016 20:05:06 GMT
You'll have to re-centre some 14 barrels with the 4x100 centre then. No biggie and super custom offsety
johnd
Jan 26, 2016 20:19:20 GMT
Lot of graft that, might have to keep 13s
MonzaPhil
Jan 26, 2016 20:39:04 GMT
FD VX490 Rostyles are 4x4 inch which is a bit closer but you'll need to check the actual design of the centre in case it's wildly different.
Not sure if they're 13 or 14 though.
johnd
Jan 26, 2016 20:52:22 GMT
Probably easiest to re stud hubs
