I'm advertising these for a friend that doesn't do forums, I can get more pics and info on request but it it really would be easier for anyone interested to contact him directly on the number posted below.
Mercedes W201 & W124 Full Air Suspension Kit
Kit will include -
x2 OCD Custom Front LCA's (Lower Control Arms) including Powerflex inner bushes and new ball joints
x2 OCD Custom Front Bag Top Hats
x2 OCD Custom Rear LCA Bag Plates
x2 OCD Custom Rear Bag Top Hats
x4 UAS Single Bellow Air Bags
All required air line fittings
All required bolts and hardware
All zinc plated to prevent corrosion and deterioration
We created this kit specifically for our W201 190E demo vehicle. After attempting to use an American made bracket kit that retains the OE LCA's all we found was the air bags rubbing on the body, suspension components and being squashed at very poor angles hugely reducing the air bags life span we went back to square one and started fresh.
The re-designed LCA's allow the air bag to be mounted on a slight angle to compensate for extreme drop and low ride heights, also the bag can be mounted much lower so is further away from the body and has zero chance of catching or rubbing agaisnt existing body work. As well as this the flat lower arm gives a good platform for the bag to roll on meaning nothing will catch or rub the air bag and reduce it's life span.
We believe this is the best way of getting not only the best drop available on these cars, it also gives the best driving characteristics, funciton and handling.
We have also compared our new LCA's, which are 15mm thick high grade steel, with air bag and top hat to the factory OE LCA and coil spring to find only a 1.5KG difference so unsprung weight isn't hugely increased but strength is.
My kit is still in the box and everything wrapped as it arrived from OCD.
i'll get better pics tomorrow
£1000
located in Wolverhampton
Advertising these for a friend so any questions please phone or text Brett on 07725882448
Kit will include -
£1000
