Feb 14, 2016 12:07:07 GMT
Oh wow that must be pretty stuck in there I'd probably soak a lot of penetrating fluid in there to persuade the piston to loosen You might be able to unscrew the bit from the top of the dashpot and poke something down from the top to push the piston out? That's the plan, it's been soaking for the past few days while we root around for a brass or aluminium punch. Wish me luck Also, does anyone know if the carburettor/manifold heat shield has asbestos on it? It's not something I want to mess with.
Feb 14, 2016 12:08:15 GMT
i have a ps complete heritage sill £35 if interested I'd have it if you were closer! But really I only need the driver's side.
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
Feb 14, 2016 13:27:45 GMT
Oh wow that must be pretty stuck in there I'd probably soak a lot of penetrating fluid in there to persuade the piston to loosen You might be able to unscrew the bit from the top of the dashpot and poke something down from the top to push the piston out? That's the plan, it's been soaking for the past few days while we root around for a brass or aluminium punch. Wish me luck Also, does anyone know if the carburettor/manifold heat shield has asbestos on it? It's not something I want to mess with. I'm sure the heat shield is asbestos so be careful I replaced mine with a stainless one as it was starting to disintegrate.
Feb 14, 2016 13:38:41 GMT
easy to post £15
Mar 19, 2016 22:37:35 GMT
I still haven't managed to start the car. I've replaced the missing ignition wire and wired the plug into the wires (no socket left on the main loom) but have two wires left over. One in the plug, and one purple wire with a spade connector towards the ignition switch itself (brand new part from MGOC spares).
I've checked the earth on the battery which is fine and then the + all the way to the starter which has some new wire fitting installed. Bench testing the starter made it shoot forward but not spin, so I purchased another which was working when removed. This new one shoots further foward but does not spin - my dad suggests this is because we can't apply power (or enough power) to all the connections required.
With this 'new' starter installed, and the ignition wire installed, with a new battery fully charged, when turning the key I can hear and feel the starter relay click and the interior light dims slightly but nothing else. I have an ignition light on the dash, and the horn and washer/wipers work.
What's the next thing to check out? I have replaced all the fuses and fixed some dodgy looking wiring, cleaned the connections on the starter relay and solenoid and cleaned some earths.
I believe my car has an ignition relay between the fusebox and radiator (though I don't think this year should). Information on this relay is very sparse. I took it apart it looked fine, however the connections were very corroded and took some of the spades with them. I cleaned and replaced them but think I have damaged the relay in the process of reinstalling it, as now the starter relay does not click.
A few questions:
- What can I do next? - Can I replace the starter and igntion relays with off the shelf versions (what amperage should I be using)? - Can I bypass these relays to test the system out? - How can I properly bench test the starter and solenoid (get it spinning)? - Is there anywhere I can simply buy the socket from the main loom to plug the igntion socket wiring in?
Thanks, I'm terrible with electronics!
Mar 20, 2016 10:19:38 GMT
A few questions: - What can I do next? Get yourself a copy of Haynes manual ... - Can I replace the starter and igntion relays with off the shelf versions (what amperage should I be using)? Yes, but not for everyday running and if you're unsure of what your doing No ... - Can I bypass these relays to test the system out? see last answer ... - How can I properly bench test the starter and solenoid (get it spinning)? see last but one answer ... - Is there anywhere I can simply buy the socket from the main loom to plug the igntion socket wiring in? Not sure what your asking here , get Haynes Manual and check wiring ... or go to an MGB spares supplier (Rimmer Bros etc) and quite the VIN number they will be able to identify model and supply correct parts ... Thanks, I'm terrible with electronics! MGB's (from factory) don't have electronics, just electrical fittings
Mar 20, 2016 15:34:03 GMT
Unfortunately the Haynes manual isn't that helpful for these parts
adam73bgt
Club RR Member Number: 58
Mar 20, 2016 18:55:08 GMT
Might be worth getting a few pictures up to explain what you mean There's a pretty good wiring diagram in the Haynes which should be good for checking you've got all the wires in the right places
Mar 23, 2016 12:15:05 GMT
OK, so here's a better explanation of what my issues are. First off, the car is a '75 (P-reg), it has the earlier dash but the only wiring guide that seems to fit is the 'Late US Market MGB from Haynes'. The car had previously had an attempted hotwiring, they smashed the steering wheel cowl, and ripped out the ignition wiring as seen below: Off the main loom the plug/socket this igntion switch wiring this connects into has been removed, leaving me with loose pins: I ordered a brand new replacement igntion switch and istalled it. I replaced the pins on the above with smaller ones that could fit in the socket of the new ignition switch wiring (above right). The fit isn't perfect but they stay inside and should carry the charge. Now all these four wires are connected to the correct colour, but I'm left with a grey (slate) wire in the socket and a purple wire heading towards the ignition switch: The grey leads to (I think) the anti run-on valve and switch which shouldn't affect starting, and the purple above leads to the key in igntion warning buzzer which is not fitted to my car. Now, underneath the car: The positive cable from the battery looks in good condition from the battery to the top of the solenoid (bottom bolt here as it hangs upside down) as are the multiple brown that connect to these. The white with brown and white with green look in good condition although previously spliced. I have replaced the connectors on one of these, as well as cleaned up the spade connector on the brown wire seen above. This starter motor is a replacement part. The previous one when bench testing shot half way forward but did not spin. For this one, the seller was sure it worked and when bench testing this new starter it shot completely forward but did not spin but I think this is because I cannot put enough power through it. Now with the igntion wire and new starter installed and connected as correctly as I think is possible, with a good charged battery, when I turn the key the igntion light comes on, and the horn and wipers and washers work. When turning the key to the start position the starter relay clicks: And the interior light dims slightly but nothing else. My car is strange in that it also has an igntion relay left of the fusebox (unplugged for this picture) which only seems to be on later cars: I don't think this influences the starting circuits however but it's strange that it's on. With the fusebox I have a few questions: - With the two pins on each side of the fuses, does it matter which one the spade is plugged into? - Originally the two brown on the bottom left were combined (badly) into one as one of the spade connectors had snapped off. I moved this broken spade to the double white above which connects to a single - is this a problem? Sorry about the long post but it's the only way to explain it all. Open to any suggestions, as previously said electronics isn't my thing!
adam73bgt
Mar 23, 2016 13:06:03 GMT
www.advanceautowire.com/mgb.pdfIf you go to sheet 31 on that link, it shows a wiring diagram for a 75/76 UK MGB which should be right for your car Looking at that diagram, the 4 loose pins you have a photo of seem to show the 4 wires that should be coming from the ignition switch Brown looks to be the live from the battery via the starter motor post White/red should be going to your starter relay White/green is an accessory power for radio and White looks like ignition live On that above link, the next wiring diagram along shows a late US car, which has a grey line from the starter motor going to the anti run on valve. But I don't believe your car should have this. A purple wire would be a constant live, linked to the brown wires via the fusebox The wires at the starter motor look alright to me compared to what I can remember they looked like on my '73 Can you get a different relay to test? On your fuse box questions 1. I think you're fine on either pin as long as its on the same fuse, two pins just allows you to have more wires coming off 2.The Brown wires in your pic look red to me but as long as they're on the bottom fuse that should be fine I'm not much of a whizz at electrics either but I think if you get everything as it should be on that wiring diagram I've linked, then thats a good start, I'd probably look at the quality of the wires and connections as well, and try and swap out the relay for another one to see if it makes a difference Hope some of that helps!?
Mar 23, 2016 19:23:50 GMT
Thanks Adam, it does help I'm looking at page 32 (75/76 UK market cars), 31 is the US market one, and yeah it looks correct minus the ignition relay which must be aftermarket. Am I correct in thinking that to get the starter turning I just need the ignition switch, battery, fuse and solenoid working? I'm trying to eliminate what I don't need to check. I'm going to head to an electronics store to get replacements for both the relays, even just temporary, as replacement metal block ones like the starter relay here are £20! The guys in there are pretty knowledgable but would I need to ask for a certain amperage, or know the pin diagram of these new relays? I have some standard Rover/Nissan/Vauxhall relays in the garage that might be useful.
adam73bgt
Mar 23, 2016 19:40:19 GMT
Last Edit: Mar 23, 2016 19:42:40 GMT by adam73bgt
Mar 23, 2016 20:25:31 GMT
Don't remember reading it , but, did you check the earth strap between engine and 'chassis' (apologies if i missed it) and the other earthing points ...
Mar 23, 2016 21:10:28 GMT
Don't remember reading it , but, did you check the earth strap between engine and 'chassis' (apologies if i missed it) and the other earthing points ... Where is that? I've checked the battery earth, cleaned it up but the battery box is corroded. Whereabouts are the others? Adam - realised what you mean about the red wires, I had to splice some of that red wire onto the brown to make it reach the fusebox
Mar 23, 2016 21:21:55 GMT
Is the battery still under the back seat ? If so the negative cable will be to some point on/near the battery box...if it's been relocated to the boot then follow the negative cable to were it joins the body and check the state of the wire and connection , if wire is green and powdery the replace, clean the contact point.
The engine to body earth starp will be a braided flat strap usually between the bell housing and nearest body point ( you may have to go underneath to see/find it ...
There are various earthing points around engine bay for things like lights, horn etc the wiring diagram will help you identify and find them, just make sure all are secure and free from corrosion.
adam73bgt
Mar 23, 2016 21:57:32 GMT
Mine also had an earth strap by one of the engine mounts, not sure how that would differ between model years mind. I think the plastic bumper cars had different mounts so the earth strap may have moved as well
Is the battery still under the back seat ? If so the negative cable will be to some point on/near the battery box...if it's been relocated to the boot then follow the negative cable to were it joins the body and check the state of the wire and connection , if wire is green and powdery the replace, clean the contact point. The engine to body earth starp will be a braided flat strap usually between the bell housing and nearest body point ( you may have to go underneath to see/find it ... There are various earthing points around engine bay for things like lights, horn etc the wiring diagram will help you identify and find them, just make sure all are secure and free from corrosion. Yes it is, the earth looks pretty sound even if the cable is a little old. The battery is transferring power so I think that can be ruled out. I've found the engine to chassis strap in the engine bay that connects to coil bracket, which seems fine too. I cleaned another earth below the starter relay but couldn't find anymore. I managed to get the original starter working on the bench correctly. Originally we connected the positive to the top terminal and another to the white & brown connection point, the gear would shoot forward but not spin. However with a fresh battery and connecting to the lower terminal directly the starter shoots forward and spins. I'm assuming that the white & brown on the solenoid is not recieving power and joining the two terminals of the solenoid together spinning it up. As the starter relay clicks, and other electrical components work I'm also assuming that the earths are fine as the starter seems to have no earth of its own. Thanks for the advice guys, I will test out the white & brown from the starter relay to see if current is getting through tomorrow - I think that's the problem of all of this. If not, it's either a secret earth I can't find yet, or an issue internally with the solenoid not connecting across its terminals.
Last Edit: Mar 24, 2016 0:22:48 GMT by Witherkay
Mine also had an earth strap by one of the engine mounts, not sure how that would differ between model years mind. I think the plastic bumper cars had different mounts so the earth strap may have moved as well Doesn't really matter as long as it's there and good otherwise 'it' tries to use the accelerator cable to earth the engine ... which get's very , very hot very quickly ! Good luck chasing the electrical continuity, one of my least favourite jobs.
Mar 25, 2016 17:28:10 GMT
I ran a replacement wire for the white/brown starter relay to solenoid wire but no change. I'll try it again but want to check the earths too. I'm having trouble finding them though. An excerpt from 'MGB & MGBGT Common Problems and How to Fix Them' suggests there's either an earth from gearbox to chassis rails, or one around the engine mounts as Adam suggested. It says that they made corrode to the point of disappearing. Can anyone confirm these earths and take a picture? Facing the car, on the right of the engine I can see this on the engine mount: Thanks
Oct 25, 2016 18:44:05 GMT
Last Edit: Oct 25, 2016 18:46:23 GMT by Witherkay
