So me and my mate fitted some alloys to his Berlingo van today. Mostly went to plan aside from a stripped bolt on the front and a little bit of concern over how much of the hub is in the centre bore of the wheel.
Basically how much is.. safe? On the back the wheels are probably about 5/6mm onto the hub but they have a cross machined into the reverse of the wheel so they don't contact all the way round? And on the front it's probably more like 3/4mm.
My concern is that the bolts will be taking all the weight rather than sitting on the little shoulder of the hub.. but I'm not sure?
Any advice would be greatly appreciated!
Cheers,
Rob.
Cheers,
Rob.
