Kieran
Jan 15, 2016 18:00:03 GMT
I've managed to get hold of a new old stock front panel for my 130RS project.
It's covered in light surface rust (I'm guessing they were oiled from new), so I want to get this off and etch prime it.
Apart from scotchbright and rust converter, any other easy methods?
Cheers guys.
Last Edit: Jan 15, 2016 18:00:53 GMT by Kieran
The Ashby Jackson fleet:-
1979 Mini Clubman 1.8 K series 1978 Skoda 110r Project 130RS K-oupe 1978 Austin Allegro 1500 SDL Estate 1984 BMW K100 Sidecar outfit 1999 Yamaha FZS 1000 Fazer 1991 Kawasaki ZXR400 race bike 2002 Kawasaki ZX9r race bike
andyborris
Jan 15, 2016 18:32:01 GMT
Me too, I need the answer to this.....!
Kieran
Jan 15, 2016 18:43:16 GMT
I guess media blasting is best or sanding with a da mouse.
Last Edit: Jan 15, 2016 18:43:58 GMT by Kieran
Jan 15, 2016 19:18:17 GMT
I was recommended Deb altrans to remove and neutralise rust, haven't got around to getting or using any so can't comment on how effective it is
rodney
https://www.facebook.com/RD-vehicle-transport-and-recovery-services-525622614268010/
vinegar
facebook: rodney dean / rd transport
Kieran
Jan 16, 2016 12:05:06 GMT
I used a devil wheel in the end (twisted knot wire wheel in the grinder).
Took about 10 minutes, watch your skin though!
steveg
Jan 16, 2016 14:05:16 GMT
I've been de-rusting pedal kart wheels in vinegar. It doesn't just make it fall off but softens it so you can easily remove it with scotchbrite or similar. Only thing I found is that it's difficult to stop it going rusty again straight away. Tried washing in the sink with very hot water then dried quickly. It still went a bit brown again though.
Kieran
Jan 16, 2016 14:58:51 GMT
It's tricky to spray anything in this weather. As soon as I had bare steel, I panel wiped it, warmed with a blow lamp and etch primed. Combination of a blow lamp, panel heater, etch primer and top coat, I got the panel protected for now.
Jan 19, 2016 14:01:38 GMT
Silicone carbide injected plastic mesh discs on a grinder , shouldn't damage the steel, but will take any surface corrosion and paint off ready to layer some lovely expoxy primer on and paint
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
Jan 19, 2016 14:03:15 GMT
These You can get em cheap enough, far better than sanding discs, don't clog or wear as quickly.
mk2cossie
Club RR Member Number: 77
Jan 20, 2016 13:32:53 GMT
These You can get em cheap enough, far better than sanding discs, don't clog or wear as quickly. I'll second these. bloody marvellous invention, and work getting anodised coating off of alloy as well
