Jul 17, 2020 16:35:18 GMT
Ive been watching with interest for a while but not commenting. nice job here getting the issues sorted out. I do like the solution for the temp sender and cooling system. motor looks great, too. Those clutch items remind me of one I did on a modern mini....it was an inbetween model and year so had some parts that fit only that model, but other parts that were more universal mini. The throw out bearing was one of them...I thought it was me putting in on backwards, frontwards, checking the clutch fork, ect, ect, ect.....We ended up finding a replacement by the part number only...references to the part were all over the place on the parts searches.
anyway...The Dauphine is looking great. following along!
JP
Jul 17, 2020 18:35:01 GMT
A couple of weeks ago ( Social Distancing Applied) during lock down I helped a friend prepare a Triumph Dolomite that had stood for some 20 years back for the road, the original clutch was freed off and replaced with a brand new three part clutch kit. No gears could be selected with the new clutch, the original was replaced in the car and worked fine. the only real difference that we could see was that the new plate was approx 1 mm thicker than the old original plate, seeing the car had covered less than 30,000 miles in it's lifetime the original was deemed serviceable. I had a similar problem with the clutch on a Skoda, a replacement clutch was fitted nothing worked, two different manufacturers produced clutches for Skoda both to the same spec but are not compatible with each other. and despite having the engine and chassis number the correct clutch could only be identified after dismantling, not much fun when you are miles away from a bus route and the motor factor with no other transportation.
Jul 17, 2020 18:42:35 GMT
Double post
Last Edit: Jul 17, 2020 18:43:41 GMT by llwynogmon
The size of that radiator compared to the size of the engine... Will it ever actually get up to temp? haha
Looks great though!
Adey
Club RR Member Number: 171
The 1957 "The Dope" Dauphine Adey
@adey1984
Club Retro Rides Member 171
Jul 18, 2020 20:31:24 GMT
Last Edit: Jul 18, 2020 20:34:08 GMT by Adey
Adey
@adey1984
Jul 20, 2020 20:36:24 GMT
The last of my bits turned up today so i got them fitted. Wiring finished and the temp switch for the rad fan fitted. Tested it at idle and allowed it to warm up and cool down over a few times over. Working great so really happy with that.
Then on to the oils. Engine oil dropped, filter changed and new oil in. Gearbox oil was another story, took about 2 hours to gravity feed it into the box. Still filled up and all good.
Right onto the test drive, its pokey and goes very well doesn't feel too bad at all. Pulls very cleanly in all 4 gears and is probably at the limit of the chassis and brakes that are on there. Only down side is it runs very hot. No leaks, no over pressurising runs very well, no smoke and no mixing of oil but when cruising along it gets hot enough to keep the fan running, so it 92+ degrees. If you pull over and idle itll drop back down on the fan. Anyway a quick chat on the drive with the mechanic neighbour and hes going lend me his timing gear and comp tester again just to set everything up. Ive just twisted and turned the dizzy till it started and left it there. His suggestion was the timing being out followed by carb jetting thought the carb looks to be an renault 8 item. I decided to do a quick search of a french renault 8 website and low and behold the first hit that came up for "température du moteur" was a chap with an r8 whos car was running very hot, fitted a new rad, cowling and electric fan only to find his timing the issue. Maybe and fingers crossed the engines are just a little sensitive to timing.
7 Mile test drive and it hasnt blow up yet.
Adey
@adey1984
Jul 20, 2020 21:11:04 GMT
Have done some more reading and found a fair few posts where otherwise fine running R8's are reading high temperatures, all have the timing incorrectly set. Fingers crossed thats all my issue is
Last Edit: Jul 20, 2020 21:21:36 GMT by Adey
scimjim
Club RR Member Number: 8
The 1957 "The Dope" Dauphine scimjim
@scimjim
Club Retro Rides Member 8
Jul 20, 2020 22:44:56 GMT
Fan’s definitely rotating in the correct direction?
Otherwise, as it cools down when it’s idling, it’s either fuel (v.weak) or ignition.
ETA - the only other option, being rear engined, is the airflow to the rad doing funky things when you’re on the move.
Last Edit: Jul 20, 2020 22:46:22 GMT by scimjim
Adey
@adey1984
Yep i have the fan sucking through in the same direction air flow would be.
Yeah that's what made me question it, though I've never really thought of ignition timing as a heat issue on previous engines the fact I've found 4+ similar threads on ignition timing causing overheating in Renault 8's and none with a popped gasket or major issues i'm confident its that. Will hopefully see later on this eve if the neighbour brings the tools home.
Hopefully not, the rad is in the same place as the original and i think ive panelled it off pretty well, could be some weird turbulence going on in front of the rad causing it though.
Jul 21, 2020 12:03:05 GMT
As you've lowered it , are the airflow dynamics changed ?
Adey
@adey1984
Jul 21, 2020 13:57:46 GMT
As you've lowered it , are the airflow dynamics changed ? hmmmm maybe, but that said i had no issues prior to the engine swap. Ran fine and at temp on the old engine at the same height.
dikkehemaworst
Club RR Member Number: 16
The 1957 "The Dope" Dauphine dikkehemaworst
@dikkehemaworst
Club Retro Rides Member 16
Jul 21, 2020 15:49:36 GMT
Air enters from the side, not the bottom. Lean, rich , timing out, all deffo hot running. Try colortune, that always works for us. How's your waterpump? And is there enough advance? Are the weights stuck in the distributor?
Jul 21, 2020 17:56:02 GMT
With the Mazda Rotaries,if you run the timing too far retarded ,you can physically get the exhaust manifold to glow red hot. Timing has a huge effect on running temperature 😊
Adey
@adey1984
Jul 21, 2020 20:05:21 GMT
Air enters from the side, not the bottom. Lean, rich , timing out, all deffo hot running. Try colortune, that always works for us. How's your waterpump? And is there enough advance? Are the weights stuck in the distributor? whats the scoop on the left hand underside for that looks like it does nothing but direct air up towards the rad? opposite side to the fuel tank. I checked the advance and its at 6degrees which is where i thought it should be. I set it back to 0 and it made no difference so ive put it back to 6 btdc. Water pump was good and looked fine when fitting. Ill colortune it tomorrow and try again.
Adey
@adey1984
Jul 21, 2020 20:54:18 GMT
So ive had a good crack at getting it to run cooler. I'm wondering if the fact the original engine ran a mechanical fan is causing an issue? Timing was checked, adjusted a few times and then set to 6 degrees. no change to temp on the dash in any setting. The dash was obviously designed for a dauphine with the sensor in a different place so maybe reading very differently. It used to be in the top of the radiator and now its in the heads water flow about an inch from the cylinder top. My rad fan cuts in at 92c (this is currently my only way to judge engine temp accurately) ive just checked the thermostat and that starts to opens at 89c so isnt fully open until 100c so i've ordered a lower temp item (that said my boiling temp should be about 120ish). I've found the info regarding the oem renault 8 stat and it starts to open at 84c and is fully open at 94c. Now I'm wondering if i have under specked the fan switch? In my head you wouldn't want the fan running every time the stat was fully open or would you? Wouldnt you want a few degrees of room on that too? If anyone could chime in on this that would be great? there seems to be no air in the cooling system at all, I'm confident its bled up well. The car runs really well, no issues at all. No mixing water with oil or smoke out of the exhaust. The water/antifreeze mix keeps its colour and the hoses don't go bar hard or swell as if taking in combustion pressure. I think i really need to sort a better way of measuring the water temp, I'm wondering if i actually have a cooling issue and am just flapping for no reason? ?
Jul 21, 2020 21:45:06 GMT
So ive had a good crack at getting it to run cooler. I'm wondering if the fact the original engine ran a mechanical fan is causing an issue? Timing was checked, adjusted a few times and then set to 6 degrees. no change to temp on the dash in any setting. The dash was obviously designed for a dauphine with the sensor in a different place so maybe reading very differently. It used to be in the top of the radiator and now its in the heads water flow about an inch from the cylinder top. My rad fan cuts in at 92c (this is currently my only way to judge engine temp accurately) ive just checked the thermostat and that starts to opens at 89c so isnt fully open until 100c so i've ordered a lower temp item (that said my boiling temp should be about 120ish). I've found the info regarding the oem renault 8 stat and it starts to open at 84c and is fully open at 94c. Now I'm wondering if i have under specked the fan switch? In my head you wouldn't want the fan running every time the stat was fully open or would you? Wouldnt you want a few degrees of room on that too? If anyone could chime in on this that would be great? there seems to be no air in the cooling system at all, I'm confident its bled up well. The car runs really well, no issues at all. No mixing water with oil or smoke out of the exhaust. The water/antifreeze mix keeps its colour and the hoses don't go bar hard or swell as if taking in combustion pressure. I think i really need to sort a better way of measuring the water temp, I'm wondering if i actually have a cooling issue and am just flapping for no reason? ? It might be worth buying a cheap infrared temp sensor to see if it is getting hot first. I can’t remember the details, but is it a mechanical or electrical sender / gauge? Are they matched? Older engines tend to have lower temp stats compared to modern engines 80-90 deg C sort of range modern engines could be over 100. The fan switch is generally higher operating than the stat like you say, with an on temp at say 100 and off at 90 to stop constant cycling. I spent 13 years testing and developing cooling systems for an OEM supplier. One car was failing all tests. We had the biggest radiator we could fit and a large wattage fan but still no good. I went up to watch testing after a year and half and all the coolant temperatures were down by 6 degrees and passing all tests just because they’d finally got the engine tune right. My van doesn’t seem to get hot even though the carb is off a 1400 and the distributor doesn’t seem to make any difference to how the engine runs no matter where you swing it. I don’t know if any of this helps.
Adey
@adey1984
Jul 21, 2020 22:01:59 GMT
strange you suggested the infrared temp sensor, I ordered one 15 min ago.
the dash and sensor are matched original 6v items the only thing that has changed in relation to them is the sensor position, it's now in the head and the engine itself.
hopefully when the temp sensor turns up it will reveal more 👍🏻
Jul 21, 2020 22:25:07 GMT
Is it showing hotter than normal in the gauge? With the fan switch temp so close to the stat temp it’s going to run but make no difference to temp when the stat is only just open. The mechanically joint radiator you have fitted doesn’t transfer heat as well as a brazed radiator And the air side pressure drop is a lot more so in the back without as much ram air as it would have in the front it could potentially struggle. Check you have a temp problem first and lower the stat temp to stop the fan running constantly before you change anything else though.
Adey
@adey1984
yeah its hotter on the gauge, that said looking around the old engine did possibly run cooler. Early ones didnt have a stat and later ones look to have had a 75c items. normal running/75c seemed to be bang in the middle of the gauge so it would make sense that an engine that runs 20c hotter has the gauge over near the warning line which looks to be around 100c. Yep ill check i actually have an issue before i go mad swapping and changing things again. cheers for the all the help jonsey much appreciated
