Geordie
North East
Course I'm out of my mind...........it's dark and scary in there!!
Jan 31, 2016 14:03:42 GMT
Ahhh Nick, that was you with the white Maxima who posted in the original FS ad for mine.
I seem to remember that you were thinking of selling yours rather than recommissioning it? If you're keeping it, and bearing in mind there are so few left, it would be wrong not to get them together at some point.
CURRENT FLEET '99 Ford Mondeo Ghia X (60k miles) '99 Alfa 166 (3 litre V6, 89k miles) '01 Mini (#869) '06 Audi A6 (18 year old 'modern' daily)
Geordie
North East
Jan 31, 2016 18:51:36 GMT
The 225/50 tyres were rubbing on full lock, slightly worn unevenly so causing a vibration, and wouldn't have allowed the car to be lowered, so time for a change. I've put some 215/45 Falkens on there now, and they sit better on the alloys.... Of course, they have increased to arch gap a bit until I get it lowered, but I can live with that for now.... Much as I loved the look of the original music system, the CD player was fubarred, and the lcd display on the radio was temperamental. I needed a decent head unit in there with wireless Bluetooth to stream the music on my phone, and a cup holder of course (essential), so I fitted my Alpine single din and a useful filler unit underneath..... Time for another coat of wax. The paintwork is coming up a treat... Another small detail. The black on the badge on the US grille was a bit faded.... so I've freshened up the black bits.... For my own benefit, list of things done so far: New battery Initial clay bar and clean Initial engine bay clean Modern dealer sticker removed Cleaned inside of rear window with tyre dressing (doh!) Leather interior cleaned and fed Headlamp wipers levelled out Original manual sourced and purchased Bonnet lifters replaced Serviced (oil, plugs and oil, air and fuel filters) USDM front grille sprayed KH2 and fitted Meshed front grille also sprayed KH2 USDM front corners fitted '4DSC' stickers fitted Towbar removed New 17" wheels Tyres (225/50/17 Falkens) Tyres to replace the ones above (215/45/17 Falkens) Things still to sort: Timing belt, tensioner and 3 other belts to change Needs lowering Rear windows to tint Remote boot release to fix Spare key to get cut Deep centre caps to find to clear the hubs Finish engine bay clean Replace headlight bulbs with Osram Nightbreaker Unlimiteds Put a layer of vinyl film over the sunroof to protect the crack in the glass Occasional sticky throttle pedal to sort (butterfly valve) Stillen body kit maybe?
Jan 31, 2016 21:04:21 GMT
Ahhh Nick, that was you with the white Maxima who posted in the original FS ad for mine. I seem to remember that you were thinking of selling yours rather than recommissioning it? If you're keeping it, and bearing in mind there are so few left, it would be wrong not to get them together at some point. It was me indeed. Still planning on selling the car, but in a year or so as I am planning on using it to commute for a bit once it has a new ticket on. There is a bit of work required on mine before I dare the trip to the MOT station, but hopefully I should be in a position to MOT it before end of Feb. After that it will be a rolling project throughout the year to sort out the "few" imperfections. BTW have you had any cold start issues on wet days? Mine never liked dampness so I used to spray WD40 on the leads and ignition module. I found it was a great help on those rainy mornings. I am all for getting the Maximas together at some point. Perhaps if you are coming down for some retro shows this yeart I could try to tie up with that. Alternatively, if you ever pop over to Birmingham/Halesowen, we can always arrange something. Nick.
Last Edit: Jan 31, 2016 21:14:03 GMT by nick0303
Geordie
North East
Ahhh Nick, that was you with the white Maxima who posted in the original FS ad for mine. I seem to remember that you were thinking of selling yours rather than recommissioning it? If you're keeping it, and bearing in mind there are so few left, it would be wrong not to get them together at some point. It was me indeed. Still planning on selling the car, but in a year or so as I am planning on using it to commute for a bit once it has a new ticket on. There is a bit of work required on mine before I dare the trip to the MOT station, but hopefully I should be in a position to MOT it before end of Feb. After that it will be a rolling project throughout the year to sort out the "few" imperfections. BTW have you had any cold start issues on wet days? Mine never liked dampness so I used to spray WD40 on the leads and ignition module. I found it was a great help on those rainy mornings. I am all for getting the Maximas together at some point. Perhaps if you are coming down for some retro shows this yeart I could try to tie up with that. Alternatively, if you ever pop over to Birmingham/Halesowen, we can always arrange something. Nick. No cold starting issues with mine Nick. I'll let you know if I'm down in your neck of the woods.
Geordie
North East
Feb 10, 2016 18:51:04 GMT
Sorted the remote boot release today. I found out from the guys on the US forum that there is a switch like a child lock on the boot lid latch. The remote boot release down by the drivers seat now works. One more little job ticked off the list. Lowering springs should be with me on Friday. I bought some Eibach's from a lad in the States. There's also an SE set of dials in the box with white faces like these..... Not sure if I like them better than the standard black dials though, so probably won't fit them straight away, but they were only $5, and I do like having the option of a change.
Last Edit: Feb 10, 2016 19:01:58 GMT by Geordie
Feb 10, 2016 21:01:40 GMT
Nice project, these are a plush looking cruiser man.
How is that drinks holder working out? Is it decent quality wise?
j4mes
Got to say Geordie you've a very eclectic mix of cars, really feeling the Maxima! Think I saw your Primera late last year heading south on the A19 near 'Boro.
Thanks for the tip about Colinite 915, it's fantastic stuff!
Geordie
North East
Nice project, these are a plush looking cruiser man. How is that drinks holder working out? Is it decent quality wise? To be honest, the drinks holder is a bit plasticy, and the pull out mechanism feel cheap, but it does the job, and doesn't rattle or vibrate, so it'll do for now. One little annoyance, the Costa insulated cup I like to use is wider at the top, so it touches the buttons on the audio lol. I'll probably end up with a double din unit in there at some point. Got to say Geordie you've a very eclectic mix of cars, really feeling the Maxima! Think I saw your Primera late last year heading south on the A19 near 'Boro. Thanks for the tip about Colinite 915, it's fantastic stuff! No worries. Yeah, I like the Collinite. It probably was my old Primera, as there are so few about, and I'm up and down that bit of road daily.
Last Edit: Feb 11, 2016 20:08:52 GMT by Geordie
Geordie
North East
Feb 11, 2016 20:10:06 GMT
THE_Liam
Yorkshire and The Humber
If at first you don't succeed... HAMMERS.
Feb 15, 2016 12:48:48 GMT
This is gonna be controversial but I actually prefer the original wheels, not that I don't like the new ones that is.
Geordie
North East
Feb 15, 2016 15:13:59 GMT
This is gonna be controversial but I actually prefer the original wheels, not that I don't like the new ones that is. Not controversial no. You're in a definite minority, judging from feedback on this and other forums, but nothing wrong with that. I have grown to like the original alloys, and appreciate their JDM'ness. They are different and I like different, but the thing is they are in desparate need of a refurb, and I had to get them off as soon as I could anyway. I will be getting them refurbed though, and I'm sure they will reappear at some point.
THE_Liam
Feb 15, 2016 16:10:36 GMT
This is gonna be controversial but I actually prefer the original wheels, not that I don't like the new ones that is. Not controversial no. You're in a definite minority, judging from feedback on this and other forums, but nothing wrong with that. I have grown to like the original alloys, and appreciate their JDM'ness. They are different and I like different, but the thing is they are in desparate need of a refurb, and I had to get them off as soon as I could anyway. I will be getting them refurbed though, and I'm sure they will reappear at some point. I think the new wheels will suit it more when it's lower, I tend to prefer aftermarket wheels on lowered cars, strange I know. Either way as I said before, I love this car, should have bought it myself.
Geordie
North East
Feb 19, 2016 20:46:57 GMT
Fitted the Eibach springs to the front yesterday. I'm sure to some it won't look low enough, but I'm not really into 'propa slammage', and just want my cars to look level and 'right' if you know what I mean. Full wheel alignment done after fitting too. Before... and now... Much better. Nice and level. Drives great too. I took it to work today, and the new springs took any speedhumps, lumps and bumps in their stride. Not a harsh ride at all. Rear half windows being tinted tomorrow, then it's basically done, and my wallet will heave a huge sigh of relief.
THE_Liam
Feb 19, 2016 22:01:30 GMT
I agree with you on that, why buy a luxury car and then slam it so it rides like a live axle truck? Nice height that, suits it well.
Geordie
North East
Feb 20, 2016 16:25:29 GMT
Parked near a load of modern boreboxes earlier today... The only car with any personality in my opinion. I love the US Maximas, and the front fogs they usually have. Like this... A while ago, I bought some fogs, and found time today to fit them. I think I like the look. Pretty sure I do anyway. Yeah, I do. I think... I was thinking of possibly tinting them yellow, but haven't, as I think it would be too many different colours with the orange indicators and slightly different orange flashes on the corners.
jpsmit
Feb 20, 2016 19:09:06 GMT
Love this car and what you are doing with it, and, obviously your choice, but I am not feeling the fogs. I really think you need a splitter to make them work, otherwise they look amateur. Sorry but my 2 cents
Geordie
North East
Feb 20, 2016 19:24:35 GMT
Love this car and what you are doing with it, and, obviously your choice, but I am not feeling the fogs. I really think you need a splitter to make them work, otherwise they look amateur. Sorry but my 2 cents Feedback on two more forums, plus FB groups, is pretty much an overwhelming 100% thumbs down for the fogs lol. As I was very unsure about them myself, I think they'll probably come off at some point. I want the car to look as good as it can, and value peoples opinions. If I was dead set on loving the look with the front fogs, I'd be keeping them, but as I'm undecided anyway, I reckon they'll be history. They might make a reappearance when/if I get the deeper bumpers of the Stillen bodykit.
Feb 20, 2016 22:14:31 GMT
I must say the body kit on that black car looks rather nice. Ironically, this guy in the US seems to have gone for the European smoked indicators and side light repetitors. Anyhow I do like the US grille that you fitted. I would be tempted to get one for my car if they're cheap enough. Good progress on your car and I do like the way the car sits on the Eibachs. Did the ones you got from the UK not fit at all then or did they look like they wouldn't fit compared with the Eibachs? Nick.
Feb 20, 2016 22:30:59 GMT
Could you not get the fogs to tuck in closer to the bumper.. up a bit and back a bit fill the gap between the number plate and the indicators but still under the bumper I think they would look good then.
hamps
www.medwayrscentre.co.uk
Feb 20, 2016 23:05:06 GMT
looking good, needs a little more lows, rear looks to high, front fogs defo don't look right in my opinion.
