Looking good!
Interesting about the balance point for the engine and gearbox. Way more central than I was expecting. I suppose the box of cogs hanging off the end is quite dense, whereas the block has a pretty big void in the crankcase. Wonder how that changes when it's full of coolant/oil though...
Darkspeed
Club RR Member Number: 39
Nov 21, 2022 12:06:17 GMT
That is full of oil ! - Engine and gearbox - compared to the overall mass a few KG of water would not significantly change the CoG - There are a few parts missing - alternator off one end - water manifold and dizzy and starter motor off the other. Intake not on but I think overall it would not move the CoG any significant amount. That point is also pretty much on the CL of the vehicle.
Last Edit: Nov 21, 2022 14:28:07 GMT by Darkspeed
Nov 25, 2022 14:57:20 GMT
Your doing a fantastic job Just reviewing what I missed in the last week I’ve be in Seville Next weekend back to reality I’ve always said it’s the last 10% that takes 90% of the time re in complete project sales
Darkspeed
Nov 25, 2022 18:42:49 GMT
Cheers sean999r - I hope to keep the momentum going and with you back in the dark and damp hopefully I will get the chance read up on your progress. On other matters - the Litton that was local to me has moved on to a new owner - A deal was discussed that was enough to make up the sellers mind to let it go. Word is that the new owner is just a county to the east of me and who knows, perhaps he will find this thread in the future has a read and introduce himself. The forecast is telling me I may well get some work done on the car over the weekend regarding the welding I want to finish so fingers crossed.
Last Edit: Nov 25, 2022 18:43:05 GMT by Darkspeed
Darkspeed
Nov 27, 2022 10:44:52 GMT
Trying to keep the momentum going so yesterday I built up the N/S drive shaft - cleaned the surface rust off the steering shaft and the alternator mount and then stripped and cleaned the O/S driveshaft. Some more painting to do.
Darkspeed
Last Edit: Dec 1, 2022 20:45:03 GMT by Darkspeed
teaboy
Make tea, not war.
It must have topped up my Karma points because I have just been offered and accepted a new Job role. so all had to do was turn up and press the trigger. Good luck with the new job. Professional hit man?
Last Edit: Dec 1, 2022 21:36:16 GMT by teaboy
Congrats on the new job! Karma indeed.
Nice one for the new job, karma indeed, Nice welding as usual too, Nigel
Darkspeed
Cheers
And in regard to my hitman side-line I shall be retaining my amateur status.... I did my big leagues time in the 1980's with Chevaline....
Cheers And in regard to my hitman side-line I shall be retaining my amateur status.... I did my big leagues time in the 1980's with Chevaline.... Polaris or horse butcher?
Darkspeed
As you know Pete on the corner is your man for butchery - And now you know where to come for advice on tuning a WMD - Although please don't - LOL I do occasionally wonder what cars MI5 are using these days for surveillance purposes - back in my day it was Mid Blue Sierra's following me around when it came around to vetting time. I am happy to say that new role is in renewables and carbon reduction technologies - So not a return to civilisation ending counter measures. Changing the subject completely - the Radiator turned up today
teaboy
Make tea, not war.
new role is in renewables and carbon reduction technologies How do you reconcile that, vis-a-vis triple Webbers?
Darkspeed
new role is in renewables and carbon reduction technologies How do you reconcile that, vis-a-vis triple Webbers? At this time I have a clear conscience even without the new job - I think my Apple tree's have the 7 litres of fuel the Stratos has used since 1997 covered with plenty of credit. I also planted a Rowan as part of queensgreencanopy.org/ and although a twig at this stage, it will be playing its part. I'm good with my carbon offsetting - Unfortunately anything good that I manage to do is undone in spades by the household generation Y's and their mates with 500BHP BMW's !
Last Edit: Dec 3, 2022 10:19:19 GMT by Darkspeed
Darkspeed
Having decided that persevering with the old rad would probably end up being a pretty fruitless task I bought a new one. It is much lighter and far less corroded which I personally see as quite a good thing on both fronts. I will need machine up and weld in a bung for a rad switch in one of the pipes to the rad depending on what temperature range I can find, or a pocket for a sensor for one of the many adjustable controllers that are available for a few pounds these days. New mounts will be required as well as a structure for mounting the fans to it. the other job done was stripping the suspension parts down ready for blasting. Just need to press the bushes out of a couple of them. Time has not been kind to the rubbers on a couple of the ball joints so I will get a full set of replacements on order.
I’m sure it’s been mentioned already but please remind me from whence those lovely uprights came? They look like they belong on a Lola or something like that.
Cheers, John
I was just thinking 'man those are natty little uprights'. Not sure why they're such a pleasing piece of engineering, but they are
Darkspeed
Please remind us where those rear uprights came from? They look very racecar-esque. Cheers, John A few high end specialist manufacturers got together and had designs done all very similar - Ultima, Gardner Douglas and Litton - Same with the steering racks that are also motorsport derived. Litton also had full alloy bell style AP racing brake set ups as well. A couple of pages back there is 308 engined Litton Corse i with the AP package on it. Manchester university had something to do with it. ETA Just noticed that the Ultima at the top is a different type
Last Edit: Dec 5, 2022 12:23:02 GMT by Darkspeed
Bother. I was hoping it would be something like 'oh, they're from the back of a Honda CRV' Very nice pieces of kit.
