Dec 14, 2015 12:15:37 GMT
Hey
So I am fitting lowering springs / eBay coilover sleeves to my Prelude.
I want to go very low and placed the spring without the sleeve on the stock strut first but there would be very strut movement available.
How much available strut movement should one aim for as a minimum?
Cheers
Current retro - 1996 Alfa Romeo GTV / Daily - 2016 Nissan Qashqai Previous retros - Prelude, Integra, XR2s, XR3s, Orions, CRXs, Sylvia S12, S13, Pulsar, ZX 16v, 205 Gti, MX5, MR2 etc
froggy
Dec 14, 2015 13:57:58 GMT
50mm plus the bump stop is the minimum I'd use
Dec 14, 2015 23:21:16 GMT
Thanks mate - what size bump stop?
froggy
Dec 16, 2015 12:35:29 GMT
They're normally 30mm on coilovers . I mean the bump stop on the damper rod
Iain
To help you search around a bit, it's called travel.
I've got away with an 25mm before, but you may find it bottoms out a bit. Cut the bumpstop down for a little bit more (just make sure it acts before the shock itself bottoms out).
Another thing to consider is whether you have the clearance to actually consider shorter shocks to allow more travel.
I would say make the bump stop bigger. maybe even take up all the space with a bump stop so as the shock compresses the bump stop acts as an ever increasing rate spring. you don't get the sudden suspension travel stop at full bump as you would with a very short bump stop. I used long VW bump stops cut to length on a CRX and it worked great. something like this cut to length
Dec 17, 2015 11:13:05 GMT
I getcha - OK thanks guys. I will have another look this weekend to see how much I can take out because it not low enough!
