Dec 14, 2015 10:07:50 GMT
At some point in the future when (IF) my mk2 golf is on the road I would like to change the dials, as atm I don't think many of them work. I have found a gauge set (http://www.speedhut.com/customizer.i?cmd=customizekit&pid=1548) but the speedo is GPS driven, are there any legal issues with using these in the UK? Ta Joe
Dec 14, 2015 10:22:22 GMT
Law states -
THE ROAD VEHICLES (CONSTRUCTION AND USE) REGULATIONS 1986 (SI 1986 No. 107
SPEEDOMETERS These must be fitted to all motor vehicles registered from 1 October 1937.
Speedometers must be maintained in good working order at all "material times" ie when a vehicle is used on a journey unless:
(a) a defect occurs during a journey, or (b) steps are taken to have the equipment repaired or replaced as soon as possible. (Regulation 36 and EC Directive 75/443)
A vehicle may be rejected at its annual test if the speedometer is not fitted, or is inoperative, is not illuminated, it has a missing or broken dial glass, etc.
The requirement to fit speedometers does not extend to vehicles fitted with EU approved recording equipment (see under "Tachographs" on page 235–239).
Under the law a GPS system, even if it gives an indication of speed, can't be regarded as fulfilling the legal requirements.
So to answer your question a GPS speedo isn't legal.
What about a tiny 52mm, legal, speedo in a pod under the dash to stay within the law whilst having the GPS item in front of you ?
Dec 14, 2015 10:26:47 GMT
curse word lol.
I tried finding that but had no luck lol.
That is an option I suppose, which I hadn't thought of.
Just wanted a nice clean set of gauges rather than having them all over the place, nothings ever easy is it lol
Ryannn
Dec 14, 2015 10:32:58 GMT
curse word lol. I tried finding that but had no luck lol. That is an option I suppose, which I hadn't thought of. Just wanted a nice clean set of gauges rather than having them all over the place, nothings ever easy is it lol It's only every 12 months, just add and remove lolll
Dec 14, 2015 13:53:37 GMT
Have "legal" speedo on a hinge so it can flip down under dash when required for MOT / Police ?.
Dec 15, 2015 10:00:04 GMT
Stick some tape over the bit that says GPS on the gauge, I can't see any other way they would be able to tell how it gets its speed signal?
If it's good enough to get holed wheel arches through an mot, I'm sure it will be good enough to get a speedo through
Dec 15, 2015 11:10:57 GMT
Will have to find a way, they are about the best looking dials I have seen lol
Rich
Club RR Member Number: 160
GPS Speedo - LegalitiesRich
@foxmcintyre
Club Retro Rides Member 160
Dec 15, 2015 13:29:49 GMT
Just remove GPS from the speedo, and leave the speedo cable sans inner drive routed to the dash. Without extensive dismantling the system looks mechanically driven, and will be fine. You are seriously all overthinking this..
robdhc
Dec 15, 2015 14:12:21 GMT
Law states - THE ROAD VEHICLES (CONSTRUCTION AND USE) REGULATIONS 1986 (SI 1986 No. 107 SPEEDOMETERS These must be fitted to all motor vehicles registered from 1 October 1937. Speedometers must be maintained in good working order at all "material times" ie when a vehicle is used on a journey unless: (a) a defect occurs during a journey, or (b) steps are taken to have the equipment repaired or replaced as soon as possible. (Regulation 36 and EC Directive 75/443) A vehicle may be rejected at its annual test if the speedometer is not fitted, or is inoperative, is not illuminated, it has a missing or broken dial glass, etc. The requirement to fit speedometers does not extend to vehicles fitted with EU approved recording equipment (see under "Tachographs" on page 235–239). Under the law a GPS system, even if it gives an indication of speed, can't be regarded as fulfilling the legal requirements. So to answer your question a GPS speedo isn't legal. What about a tiny 52mm, legal, speedo in a pod under the dash to stay within the law whilst having the GPS item in front of you ? I realise I am most likely being incredibly thick, but I can't see where it says that a GPS speedo is illegal? Just because it's using GPS to show speed rather than cable / whatevermoderncarsusethesedays I don't see how it's no longer a speedo? Thanks, Rob
Iain
Dec 15, 2015 14:59:14 GMT
Surely driving it on the brake rollers and the speedo not showing any speed is a reason for failure?
Dec 15, 2015 16:57:18 GMT
Surely driving it on the brake rollers and the speedo not showing any speed is a reason for failure? Testing the operation of the speedo is not part of the MOT. It just has to look like its operational. Legality of having a working speedo is a different matter :-)
Dec 15, 2015 19:06:37 GMT
There's no definition of a speedometer so a dedicated one relying on GPS satalites should be fine. A GPS navigation unit that also showed speed would be questionable unless it was permenantly fixed. Wireless speedo on a motorcycle is fine
Dec 15, 2015 20:02:37 GMT
Hi, a lot of car nowadays get their speed signal from ABS wheel sensors so there is no direct mechanical link with the wheels. So it could be argued there's no difference to a GPS signal providing the information, only the distance. How accurate it is is another matter because GPS only registers lateral or horizontal speed and can't be accurate when going up or down a hill. The issue with the MOT comes down to whether there is a speedo actually present. They don't or can't test its operation. So as long as there is what looks like a speedo then that should be enough.
Colin
Dec 15, 2015 22:39:44 GMT
A GPS speedo will pass an MOT as the speedo itself is not tested.
Dec 15, 2015 23:00:21 GMT
Hi, That's more about construction and use compliance than MOTs. Colin
Rich
@foxmcintyre
The car isn't being IVA tested. The long and the short of it- no. It's not 'legal' Will you get 'caught'? Highly Unlikely.
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Dec 16, 2015 10:25:04 GMT
A 'mate' of mine hasn't had a working speedo for about 4 years now. Remarkably 'he' hasn't got nabbed speeding either! Lack of mileage at MOT time is easily explained by the oddometer being broken
Dec 16, 2015 12:03:42 GMT
In mid 70's a mate got stopped for speeding in his 13/60 Herald convertible. Officer asked him if he realised what speed he was doing which he replied speedo wasn't working. Officer reached under the dash and found cable disconnected and mate then admitted it was to stop miles being clocked up as already higher than average. He got done for speeding and an additional charge relating to the disconnected speedo (can't remember the exact offence) !
Iain
Dec 16, 2015 16:08:10 GMT
Surely driving it on the brake rollers and the speedo not showing any speed is a reason for failure? Testing the operation of the speedo is not part of the MOT. It just has to look like its operational. Legality of having a working speedo is a different matter :-) If you're driving at 10mph on brake rollers and it's reading 0mph, then that to me would look NOT operational.
