I'm after a mig welder , air compressor with about 50l tank to play about with (learn to weld ect)
Also after a cheap tool chest ideally I can ground anchor to floor and tool cabinet so any recommendations appreciated
Built to a standard ready to be modified to perfection
1995 Charcoal Rover 220 GSIT (WIP)
Cavs
Dec 13, 2015 23:19:52 GMT
Where are you mate??
Dec 17, 2015 22:24:47 GMT
Swindon mate but willing to travel for right stuff
nigxl
Dec 18, 2015 22:55:25 GMT
Got an almost new Sealey 100 lt with separate motor and compressor unit. Been run for 20 mins max in clean air to spray a boot lid on an MX5, found I was no good at spraying so decided to give up. You'll need a fairly meaty compressor to drive any sort of air tools, 50lt will probably be no good to you. I paid over £500 for the Sealey when it was on the sale and I'd like £350 for it. Comes with all the books and even still has the plastic on the gauges. In South Wales however so may be too far for you.
nigxl
Dec 19, 2015 17:40:50 GMT
Dec 20, 2015 13:40:22 GMT
If it helps, I have a Clarke 120E MIG also in South Wales (RCT, 45 miles from Severn Bridge). £80 to include lots of new consumables (tips, shrouds, insulators, etc.). Collection only.
Contact O758O 8OO579
Dec 21, 2015 13:59:58 GMT
Got an almost new Sealey 100 lt with separate motor and compressor unit. Been run for 20 mins max in clean air to spray a boot lid on an MX5, found I was no good at spraying so decided to give up. You'll need a fairly meaty compressor to drive any sort of air tools, 50lt will probably be no good to you. I paid over £500 for the Sealey when it was on the sale and I'd like £350 for it. Comes with all the books and even still has the plastic on the gauges. In South Wales however so may be too far for you. If this isn`t right for Squiggles, I may be interested. Where abouts in S Wales?
nigxl
Dec 21, 2015 20:14:23 GMT
Nr Milford Haven Pembrokeshire
Dec 22, 2015 22:49:27 GMT
Andy classics I've pmed you and 103keef go for it as I've had put the air compressor on hold for a month
Dec 23, 2015 10:12:19 GMT
No PM from you in my inbox.
