Nov 23, 2015 19:11:22 GMT
*update* - more build photos on page 2 I need to dig through all my pictures of the build and put them in order but for now here is a couple. I am getting very close as soon as my lsd arrives it will be ready to hit the road Nissan ca18det T3/t4 turbo Skyline 444 injectors Oil capacity increased to around 6 litres from 3.8 stock Link g4 xtreme ecu, closed loop boost and fuel control etc etc Competition clutch 6 puck paddle Nissan s13 steering rack and full power steering setup Digital dash Oldskool nardi steering wheel Fully rewired to use a pair of modern fuse boxes Battery in boot Fuel system encased in an alloy box for stealth Neaty_boy limited slip diff, front tubular arms, arb drop links Almost stock appearance!! First run
Last Edit: Nov 29, 2015 21:17:11 GMT by Hudzoyne
choaky
Nov 23, 2015 19:18:38 GMT
Awesome! Gotta love a sleeper
Escort Mk4 ST170 powered sleeper Instagram: @f670_pur
BLU
Nov 23, 2015 19:23:18 GMT
Much like
The future's bright, the future's BLU
Silver 1987 MK2 Fiesta Ghia White 2006 MK6 Fiesta ST150 Yellow 2007 MK6 Fiesta Zetec S Anniversary #279 Green 2007 MK6 Fiesta Zetec S Celebration #471 (diesel conversion) Red 2008 MK6 Fiesta Zetec S Anniversary #893
pork
Nov 23, 2015 19:28:39 GMT
Tits !!!!!
thebaron
Over the river, heading out of town
Nov 23, 2015 19:34:40 GMT
Aaargh cant see the video and I need to.
This looks amazing
Nov 23, 2015 19:37:29 GMT
Nothing too exciting just a run and few revs. Bit of chatter though! Will have lots of action videos once it's on the ground and I have tuned it.
See if this works
steveg
Nov 23, 2015 19:46:04 GMT
Oh yes ! that works just fine
Carlosfandango.
Now with added Suffix B Range Rover classic - another bucket list car acquired.
Nov 23, 2015 20:33:49 GMT
Love it. And like has already been alluded to, it's the tits.
CFD
1966 Fiat 1500 fast road/race conversion 1967 Porsche 912 1968 Fiat 124 Spider 1973 Range Rover Suffix B 1993 Series one Discovery 200TDI 1997 Jaguar XJ6 3.2 sport 2001 P38 Range Rover 2.5 TD Brace of Triumph bikes
luckygti
I need to try harder!
Nov 23, 2015 21:08:48 GMT
Oh yes, now that I like. I keep thinking that my Escort should really have an engine like this!! Looking forward to a few more build up pics and info.
dikkehemaworst
Club RR Member Number: 16
Nov 23, 2015 21:13:41 GMT
gazz81
Nov 23, 2015 21:54:57 GMT
That looks insane! Can't wait to see the action video.
g52oyc
Nov 24, 2015 11:01:26 GMT
That looks like it will be a cracking toy. Have you baffled the sump aswell as increasing capacity? Got a CA in my bluebird but obviously front wheel drive so wrong configuration. Good engines, bad reputation for running the bottom end dry but obviously cured with increased capacity and baffling the sump if your going to stick it sideways. Heads also tend to breathe heavy so a decent breather setup and keep it nice and clean is always helping towards its health. I noticed on 1 i have on the engine stand the standard oil coolers sludge up and get blocked so may be an idea to get an aftermarket if you haven't already . Enjoy!
Nov 24, 2015 11:05:54 GMT
That looks like it will be a cracking toy. Have you baffled the sump aswell as increasing capacity? Got a CA in my bluebird but obviously front wheel drive so wrong configuration. Good engines, bad reputation for running the bottom end dry but obviously cured with increased capacity and baffling the sump if your going to stick it sideways. Heads also tend to breathe heavy so a decent breather setup and keep it nice and clean is always helping towards its health. I noticed on 1 i have on the engine stand the standard oil coolers sludge up and get blocked so may be an idea to get an aftermarket if you haven't already . Enjoy! Yes all baffled and trap doored, aftermarket oil cooler and stock completely removed. Also changed the breather pipe that is common for blocking that leads down from the rear of the cam cover to the crank case. Tuning is also a big part of what kills these. Look at 90% of the CAs in this country they will be on a stock ecu and horrible plug in chip. Look to Scandinavia where they have seen 600hp unopened!! and they will be properly tuned on proper ecus which is why I am running this on one of the best available and will spend a lot of time tuning it properly......Also helps that I am a link dealer
Last Edit: Nov 24, 2015 11:07:32 GMT by Hudzoyne
g52oyc
Nov 24, 2015 11:14:49 GMT
Yeah, i'm on stock ecu but no dodgy mass produced chip tuned on an engine completely different to mine, I considered nistune but i have a few other toys to play with before I hunt for more power on the CA. Do you do link ecus for Toyota Chaser jzx100's? Also may be after management for my Nissan Cedric .
Nov 24, 2015 11:16:59 GMT
I don't believe there are any plugins for the jzx range but you can of course use a wire in. This is a wire in as I had an xtreme laying around and made sense to use it.
I am also a nistune dealer and the cheapest in the UK as it's more of an obsessive hobby than a 'business' any enquiries drop me a PM and I am sure I can sort you out with some very friendly supply prices along with fit and tune of required.
Nov 24, 2015 11:22:39 GMT
Is that Zirotec coating?
Used on my sleeper project's DP (have a look at my signature link)
The sleeper concept has so many pros and a Lada estate is a great choice.
Nov 24, 2015 11:24:26 GMT
you are just down the road! - i'm close to Hunstanton.
Nov 24, 2015 11:34:17 GMT
looks very nice...how it should be done
will it be on stealthy looking wheels? please say yes
Nov 24, 2015 11:42:12 GMT
looks very nice...how it should be done will it be on stealthy looking wheels? please say yes It's on bright red banded steels at the moment it's been around a bit on this forum only done 13,000 miles from New. It will be on revo 5 spokes as they came from the factory black with a slightly polished lip. So not mega stealthy but just nice and subtle giving you a hint it might not be quite standard
