I am after some suggestions here.
I got this last year, i bought it home for my garage and it did its job very well, that was until we moved house and my garage was replaced with a smaller work shop. Because of this it has sat under my car port unused. Its a huge waste and it needs to go really.
The table is a huge industrial item. I work for a stainless fabricating firm and we make some pretty tough stuff so the bench has been tailored to suit.
It measures about 2500mm long and is about 1500mm deep (i will have to have a go at it with a tape again soon, I have forgotten exact measurments).
The table is fitted with 4 very large steel wheels, 8" i think, braked, two turn, two don't. It has a shelf inside and is clad with 1.5mm stainless.
The top is 10mm Mild steel and the top is clad with 2mm 316 grade stainless.
It is a very heavy, very sturdy thing, i moved it in a LWB van. I loaded it up at work with a forklift, when i unloaded it i realised it was very heavy! You can load and unload it by hand, but there will have to be 2/3 people as its a fair old lump. I assume you should be able to move it in a T5 sized van.
Is this going to be worth anything? I was going to crack the plasma cutter out and cut it up and throw the metal in my stores but it seems kind of like a waste.
I do have photos on my old phone. Any ideas on price?
