Hey guys, anyone following my carlton build thread will know I am fitting a 1UZFE V8 into my carlton with a manual gearbox.
The flywheel is a modified 3SGTE (Toyota MR2 Turbo) unit, now the obvious choice is a 3SGTE pressure plate. Trouble is because its MR2 turbo unit its got the tuners tax on it and in addition some people have had issues with the release bearing being too small and not pushing the springs correctly.
There are two cheaper options I have seen mentioned several times, Toyota Hilux and 4runner. The issue I have is which type as there seems to be different engine and year variants. Anyone got any insight?
The gearbox I am using is an Omega V6 R25-28 5-speed with a concentric hydraulic slave cylinder.
John.
John.
