Jan 15, 2018 11:27:00 GMT |
1987 Supercharged BMW R1150 Citroen 2cv Hillclimb Monster 1995 Renault Master Mk1 Race Transporter 1994 Mazda MX5 Mk1 / NA Road Going Class Hillclimber 1991 UMM Alter II Crew Cab OM606 SuperTurbo Diesel MegaUMM Overlander 1992 UMM Alter II Station Wagon 1980 UMM Cournil - survivor - resto project 1979 Lomax 224 2014 VW T5.1 Transporter Kombi Highline
Jan 15, 2018 15:55:55 GMT |
An idle day at sea.. some ideas start flowing for a completely separate auxiliary wiring system.. IMG_3567 by Alex de Vries, on Flickr Power and earth distribution board on the right that also has built in fusebox. Very handy for running a whole separate system. The waterproof junction box on the right has relays in it. I have three of these about the vehicle that house relays for heated mirrors, horn, onboard 12v power, spotlights, rear work light etc. IMG_4953 by Alex de Vries, on Flickr Dash cut for switchgear (there were just a single rear foglight and unused single front foglight switches here hence the yellow connectors, these I worked out the wiring for and replaced with my connectors for the Carling Switches. IMG_4913 by Alex de Vries, on Flickr Front winch isolator, rear winch isolator, work light, front floodlights, heated mirrors on the carling switches. All wiring using proper crimped connectors with heat shrink over the top of the crimps. No crappy plastic crimps here! Also note new boost gauge, fits in nicely with the stock air vent. IMG_4938 by Alex de Vries, on Flickr Made up this plate to bolt to the front bumper (rivnuts in bumper) IMG_4946 by Alex de Vries, on Flickr New front spotlights. Super power. Direct copies of the ARB spotlight (800 a pair I think?!). 130 via Alibaba express. Would recommend.. IMG_4949 by Alex de Vries, on Flickr All the wiring heatshrunk and then run in these stainless P-Clips to stop it being ripped out by trees, deer etc.. run back to the relay junction box you saw earlier. IMG_4960 by Alex de Vries, on Flickr Note the ghetto cable tied Warn 9.5xp winch controller/solenoid box on the above photo, you can just make out that it is cable tied to the bullbar. Enough of that, time to make a proper mount. Also note the chuffing huge intercooler.. although that is another story. IMG_5549 by Alex de Vries, on Flickr IMG_5551 by Alex de Vries, on Flickr You didn't think I was going to run all of this and two winches off of just the stock single battery did you...? Twin yellow optimas are the bomb. I don't think you could get a better heavy duty battery. IMG_5451 by Alex de Vries, on Flickr Gonna need this lot.. IMG_5581 by Alex de Vries, on Flickr Locating them both here though wasn't easy. A lot of small fabrication of mounts, plates and moving the coolant reservoir, power steering, air intake etc etc etc.. IMG_5614 2 by Alex de Vries, on Flickr But wait one.. what is that funny box in the last picture? This is a Sterling Power Pro Split R. It is not possible to use a traditional heavy duty split charge relay in this situation as when running th ewinch at its full 9500lbs recovery rating it would draw 482 amps, the strongest relay I could find was 200A, so thats a bit of a fire risk.. The Pro Split R works as a zero voltage drop alternator distribution system capable of charging both batteries without the need for a split charge relay from one to the other. It sits inline after the alternator and distributes power as it sees fit. It is intelligent in that it monitors the main power battery and gives this priority for charging but otherwise will charge which one is needed. Whilst it will not be possible to top the secondary battery up with a draw of 425A from a fully bogged down winch pull I will provide up to 120A without dropping out and crucially without melting. If pushed over this it will intelligently limit itself to 120A rather than overstretching itself. IMG_5582 by Alex de Vries, on Flickr I then compartmentalised the area over the passenger wheel well to hold the Pro Split R, the original glow plug relay box and the winch power supply relays. The Pro Split R outputs I also put mega fuses inline and you see their boxes here too. Every cable is properly crimped and heat shrunk, even the battery cables. All the cables even the battery ones are marine grade tinned wire as well. Should be just the ticket for this muddy wet machine. You can see the re-sited coolant reservoir and power steering reservoir too. Don't worry, the battery hold down clamps are heat shrunk as well. IMG_5727 by Alex de Vries, on Flickr I couldn't do all of that and not want to monitor what each battery is getting though... this is an Ironman dual battery monitor that I brought back from Australia and wired with 1.5mm tinned wire form the main battery terminals. It is also wired straight to the positive ignition feed that is on the Sterling Power Pro Split R straight from the Alternator. It fits nicely under the carling switches on the dash. It took me a really long time to find a battery monitor that looked how I wanted and did just that. Keep it simple eh. IMG_5787 by Alex de Vries, on Flickr *BONUS SHOT* everything works. LEDs. Nice. IMG_5783 by Alex de Vries, on Flickr A passing thought is that all this kit or just the cost of one new winch is the same amount as I bought the UMM for in the first place. Does this matter? I think not. I love a good project, and now I'm excellent at wiring.. skills betterered.
Jan 15, 2018 18:09:14 GMT |
Jan 15, 2018 21:14:31 GMT |
So where does that lead us now? And why has the title of this thread changed from one UMM to two... Well.... I found a barn PACKED and I mean PACKED, nose to tail, side to side, with project UMMs, from complete vehicles that would be easy projects to absolute basket cases. We shall call this, the UMMporium. This is the entrance and fortunately it was this first one that I had specifically come to see. IMG_8971 by Alex de Vries, on Flickr IMG_5238 by Alex de Vries, on Flickr IMG_5239 by Alex de Vries, on Flickr So what's the deal, I'v already got an Alter II right.. correct.. but this is more than it seems (yes I KNOW it seems a rusty ducked heap..)... it is almost twice what it seems.. IMG_5242 by Alex de Vries, on Flickr HOLY HORSE curse word curse word. That is an extra set of door holes. A mythical RHD crew cab pickup/stationwagon. There are only three other RHD crew cabs. One is the original UK demonstrator that was a crewcab pickup and is an absolute wreck and now owned by an UMM collector, the second and third are both crew cab station wagons (removable back sections) and onsite at the UMMporium. The second will never be sold, but this one was.. to me.
pegwie
I bet it didn't take much umming and ahhing before you decided to buy that! Umm, puns aside though, did the doors come with it & what's the plan?
I'd never heard of these until last week when I was randomly looking up BMW M51 engines and apparently, they were fitted to these!
An M51 powered UMM. Now that would be a sweet gig.
Umm-porium. Love it.
So where does that lead us now? And why has the title of this thread changed from one UMM to two... Well.... I found a barn PACKED and I mean PACKED, nose to tail, side to side, with project UMMs, from complete vehicles that would be easy projects to absolute basket cases. We shall call this, the UMMporium. This is the entrance and fortunately it was this first one that I had specifically come to see. IMG_8971 by Alex de Vries, on Flickr IMG_5238 by Alex de Vries, on Flickr IMG_5239 by Alex de Vries, on Flickr So what's the deal, I'v already got an Alter II right.. correct.. but this is more than it seems (yes I KNOW it seems a rusty ducked heap..)... it is almost twice what it seems.. IMG_5242 by Alex de Vries, on Flickr HOLY HORSE curse word curse word. That is an extra set of door holes. A mythical RHD crew cab pickup/stationwagon. There are only three other RHD crew cabs. One is the original UK demonstrator that was a crewcab pickup and is an absolute wreck and now owned by an UMM collector, the second and third are both crew cab station wagons (removable back sections) and onsite at the UMMporium. The second will never be sold, but this one was.. to me. They remind of Jowetts (not that Jowett ever built a 4 X 4) but unusual and if fettled & sorted can become a reliable & rare alternative to the usual market offerings!
Jan 16, 2018 10:01:20 GMT |
I bet it didn't take much umming and ahhing before you decided to buy that! Umm, puns aside though, did the doors come with it & what's the plan? Haha! Umming and ahhing.... I'm going to use that as my own. It came with pretty much everything, the TEN original seats, all fixings and fittings, doors, spare bonnet and tailgate, all the glass etc. You'll have to wait for the next set of pictures to start seeing the plan... but basically... - mint bodywork, in company black and turquoise - remove rear canopy over loadbed, possibly install a 750kg HIAB/Palfinger & tool lockers - rebuild & truss axles and drivetrain - rear disc conversion - meaty tyres & lift - cage over the crew cab area - brand new Cummins R2.8 diesel - an interior you wouldn't believe if I start explaining it now Future proofing & super upgrades, eventually if I ever decide to trailer green car then this will probably win as tow vehicle over the current T5.
Jan 16, 2018 10:05:42 GMT |
I'd never heard of these until last week when I was randomly looking up BMW M51 engines and apparently, they were fitted to these! Sadly all the late Alters were Peugeot XD3 or XD3TE fitted, 2.5 lumps out of the really boxy saloon & pickup they produced. Only one M51 prototype was ever built with a factory supplied BMW motor. This was right at the end of UMM production and it never got any further. The vehicle still exists and has recently been rebuilt by Peter Tumble Motorsport in Portugal. If only...
Speedle
Jan 16, 2018 10:10:47 GMT |
What an awesome beast this is! I've never even heard of these until now.
Jan 16, 2018 10:11:08 GMT |
So where does that lead us now? And why has the title of this thread changed from one UMM to two... They remind of Jowetts (not that Jowett ever built a 4 X 4) but unusual and if fettled & sorted can become a reliable & rare alternative to the usual market offerings! Truly, sadly as secondhand vehicles they were bought cheaply and usually repaired and maintained on a similar theme. Once you get one sorted from it's previous neglect then it really is a bombproof and dependable vehicle. I've the little one on it's side and driven it up all sorts of things without denting it (thick steel) or breaking any mechanicals. Anything that has gone wrong has been noticeably unloved and ill maintained in the past. I wouldn't hesitate to jump in the small one and drive it to Scotland and back.
düdo
wide as house
Jan 16, 2018 10:53:00 GMT |
greencarfritz said Don't you mean 'The Cape' and back? Cmon man, gotta set your sights on something a bit further out now you've got it all rigged up for adventure.
Jan 16, 2018 10:58:07 GMT |
that would be epic with a 2.2 HDI.
Jan 16, 2018 11:01:57 GMT |
that would be epic with a 2.2 HDI. Cummins R2.8 crate motor, incoming.
Jan 16, 2018 11:11:06 GMT |
yeah I did see, shame not to keep it french! though have seen decent things from the R28 project with the dirt every day guys on motortrend.
Jan 16, 2018 11:32:36 GMT |
So I'd already been to check it out and I knew I'd have to return with the van and all of my tools to get it rolling again. The front axle was attached but no stub axles, wheels etc. The rear was sitting on a wheeled frame with no room either side to get the axle in. And obviously it was full of its parts. Poor UMM. I got the front loosely back together, hooked up the steering and we started to drag him out of the barn using another (operational) UMM. IMG_8980 by Alex de Vries, on Flickr Found a rear axle from a turbo Alter II in another barn.. needs a rebuild but will do for getting it on the trailer and into the Super Secret Shore Base (ahh yes, we finally have our warehouse).. Slightly hefty to get back in. IMG_8979 by Alex de Vries, on Flickr IMG_8981 by Alex de Vries, on Flickr And back on all four wheels for the first time in a long time! IMG_8985 by Alex de Vries, on Flickr Once cleared out you can see the internal structure is pretty good. The rear floors and seat box are good, the sills are a little crispy and dented in places but will be replaced by box section so I can use my farm jack straight off of them, and the front floors may be salvageable but I'm planning on new metal currently.. IMG_8982 by Alex de Vries, on Flickr Dragged it up to the top field out of the courtyard for a better look around and a pressure wash off of barn grime. IMG_8992 by Alex de Vries, on Flickr I like to think the T5 is sitting in the background wondering WTF is that. IMG_8993 by Alex de Vries, on Flickr Ratcheted a spare bonnet inside, also ratcheted the roof and bonnet on, the rear door and loadbed full of seats. All the parts went in adventure van with me. IMG_8994 by Alex de Vries, on Flickr IMG_8986 by Alex de Vries, on Flickr And that was the last that MegaUMM shall see of the UMMporium for a couple of years.. trailered to his new home at the Super Secret Shore Base in deepest darkest Devon.
melle
South West
It'll come out in the wash.
Jan 16, 2018 11:39:32 GMT |
Great stuff, keep it coming!
PS: you have a very Dutch name for an Englishman.
Rob M
Club RR Member Number: 41
Jan 16, 2018 12:42:43 GMT |
I was working at a certain local Airforce base the other week where I spotted one of these parked up. I was then thinking about how much of a grin it would be to own one, if one could actually be found within a decent price range. I then thought about an UMM as a cheaper alternative and, today, you update the thread! It does seem a tad ridiculous that more than capable alterrnatives to the Landy have always been out there but just have been overlooked. Nice to see something different given a bit of love and attention, great read!
Jan 16, 2018 12:48:17 GMT |
Only one M51 prototype was ever built with a factory supplied BMW motor. This was right at the end of UMM production and it never got any further. The vehicle still exists and has recently been rebuilt by Peter Tumble Motorsport in Portugal. If only... You don't find a BMW six more appealing than a Cummins 2.8 then?
