I've acquired a v2 megajolt unit I've tried to find out how to wire outputs such as the rad fan and fuel pump - can anyone help?
Btw I was going to use a Ford temp sensor possibly off a mondeo/ zetec
BT
How many pins are on the molex plug?
I think there are either 14 or 16 one being older one being new.
BT
I'll check the plug when I get it delivered, thanks for the advice too - I'm hoping to have the cortina running it and control the fan and fuel pump to make everything easier and free up ign lives!
I'll check it out but both the fuel pump and fan would need a relay anyway so it wouldn't be an issue
Midas
Club RR Member Number: 14
Megajolt outputs Midas
@midas
Club Retro Rides Member 14
I'd guessed that would probably be the case, but it bears repeating as you never know what people have in mind. It's a great system when it is up and running, I wish they would make an EFi version
MrSpeedy
East Midlands
www.vintagediesels.co.uk
I'd guessed that would probably be the case, but it bears repeating as you never know what people have in mind. It's a great system when it is up and running, I wish they would make an EFi version Wouldn't that be a Megasquirt?!
Midas
@midas
I just found I preferred the directions and support offered for the Jolt over the Squirt. Hard to put my finger on what it is exactly.
MrSpeedy
East Midlands
Well I'm a complete computer fucknugget, but managed to get it together with a couple of months of evening reading.
If I can do it, most others could I'd have thought. Or maybe I just got lucky?! lol
Nope, I managed it too. In fact I've managed it 3 times now. If I only did it more often I might not forget everything I learned and have to start from scratch each time.......
Strangely enough, when I've be called on to try and figure out someone's malfunctioning 'jolt it causes real mental pain - I think it's the way the map table is the other way up.....
Nick
Is the mega jolt still available in kit form then? Anybody got a link?
