...V8 TWIN TURBO!
speedoptions.com/articles/4696/
PRISM MOTORSPORT BMW E30 V8 TWIN TURBO
Normal Race Conditions Power Output @ 8 PSI
548 bhp
580 lb/ft @ 6200rpm
Qualifying Power Output @ 23 PSI
670 bhp
700 lb/ft @ 7200rpm
Engine
All alloy TVR based unit 5.0 L twin turbo injection
4 bolt main
96.3mm top hat liners
Forged and coated WRC pistons
H-section steel rods
Steel billet knife edge and tuff-ride crank cross drilled
Special profile cam with dual adjustable timing gear
ARP bolts throughout long stud conversion
Group A trap door sump and crank scraper with external oil pick up
Heads special cast alloy heads with twin external oil returns
Super large inlet and exhaust valves
Pro comp roller valve gear
Hardened push rods
1.3mm cooper head gaskets
Induction System
Twin roller bearing turbo units T28/T40B water-cooled special built units
Front mounted air to air intercooler
Twin Alloy air boxes with integrated 52mm ram air trumpets
740cc injectors on 48mm throttle bodies twin swan neck manifolds
Management system by SDS self program
548 bhp
580 lb/ft @ 6200rpm
670 bhp
700 lb/ft @ 7200rpm
Engine
4 bolt main
Hardened push rods
Induction System
