Still got mountains of this stuff, repasted here to speed things up. All parts pictured for £20 ex delivery unless otherwise stated.
![](http://i.imgur.com/0nmC9kc.jpg)
Cores in good condition, but fins may benefit from straightening on top side for improved efficiency - £40
![](http://i.imgur.com/jyuNX7k.jpg)
PS Pump, classic. Could use a clean, but ran great on car with no noises. Clean fluid removed when unit was drained.
![](http://i.imgur.com/JWEjTzP.jpg)
Classic sidelights. No bulbs or holders, but securing tabs and such in very good condition. Plastic glass perfect. £10
![](http://i.imgur.com/mZ65D5s.jpg)
Dash lower steering surround complete 15 plus postage
![](http://i.imgur.com/JP2jpaR.jpg)
Steel Header Tank 10 plus postage, VGC
![](http://i.imgur.com/GGa1Z7g.jpg)
![](http://i.imgur.com/OFzjW8R.jpg)
Clock Surround 10 plus postage - VGC
![](http://i.imgur.com/Z21VmfT.jpg)
steering column cowl, no cracks, GWO. £10 plus post.
![](http://i.imgur.com/axcekaI.jpg)
2 port EBCS 10 plus postage, Good upgrade for higher power mods on cars with 3 ports (google)
![](http://i.imgur.com/ovhR6zP.jpg)
Version 4 to 6 Clocks. 20 plus postage - MPH readout
![](http://imgur.com/tMVkaI1.jpg)
Facelift interior heater controls, Comes with cables, all decent condition, no bent lines etc...
![](http://i.imgur.com/0q7lraM.jpg)
Door lock relay, £5 plus post.
![](http://i.imgur.com/1wTVinx.jpg)
![](http://i.imgur.com/QDNzy7o.jpg)
Drivers Side Control Unit 20 plus postage
![](http://i.imgur.com/DNMuryl.jpg)
Headlights 20 each or 30 for the pair. Plus postage
![](http://i.imgur.com/dcljMLC.jpg)
New Age TMIC breather 10 plus postage
![](http://i.imgur.com/0JCpI55.jpg)
Gear surround trim. 10 plus postage
![](http://i.imgur.com/560tiIl.jpg)
![](http://i.imgur.com/zQA6sVi.jpg)
Big scoop, Classic Fitment, 20 plus postage
![](http://i.imgur.com/DYn5WPc.jpg)
Interior Handles £5 plus postage the pair. VGC with screw covers present. Comes with screws.
![](http://i.imgur.com/G89lk7A.jpg)
Fuel Pump (stock wrx) including cradle and top plate £10 plus postage
![](http://i.imgur.com/JQBjkJ5.jpg)
Top dash cubby 20 plus postage. hinges in good nick.
![](http://i.imgur.com/4Vy4r0u.jpg)
Impreza classic facelift blower motor and flaps - £20 plus postage
![](http://i.imgur.com/Ps3Rdbi.jpg)
Center dash frame 20 plus postage. Good condition, with stereo holder for JDM bolt in units
![](http://i.imgur.com/VjYTmr3.jpg)
Recirc pipe and bung. £10 plus post
![](http://i.imgur.com/u5hMDWM.jpg)
Seat belt covers 10 each or both for 15 plus postage. B pillar trims - all tabs present, good condition. Facelift interior
![](http://i.imgur.com/cW4F1SO.jpg)
Rear quarter seat belt trim 10 each or two for 15 plus postage. C pillar trims - all tabs present, good condition. Facelift interior
![](http://i.imgur.com/NdK76Wk.jpg)
ECU, suspect V4. £10 plus postThis was removed from a version 4 classic WRX. Any responsibility for unit should be buyers, check serial numbers for verification. Unit in GWO, ran car fine.
![](http://i.imgur.com/16U9xP7.jpg)
![](http://i.imgur.com/raPOSWQ.jpg)
Heater matrix. £20 plus post
![](http://i.imgur.com/Fx36Bxn.jpg)
Airbag ECU. £10 plus post
![](http://i.imgur.com/5pf3cMJ.jpg)
Momo Classic Steering wheel with airbag £20
![](http://i.imgur.com/A7KJs6z.jpg)
Rear parcel shelf 20 plus postage, no splits or cracks, good condition black felt.
![](http://i.imgur.com/b5ku4AF.jpg)
Facelift glovebox unit. £10 plus post
![](http://i.imgur.com/5GFvDpg.jpg)
Lightweight STI flywheel - £50 plus post, Lightweight flywheel. Unused, light surface rust will clear off. £50 plus post.
![](http://i.imgur.com/TgzFF8U.jpg)
Coil plus leads. V3/4. £10 plus post.
![](http://i.imgur.com/CxTXFt1.jpg)
Aftermarket intake. £30 plus post. Brand new. Not sure on revision, please check first. Fits under intake to turbo.
![](http://i.imgur.com/wnzXxtR.jpg)
As new engine mounts. £20 plus post. Fitted prior to scrapping of car, barely used.
![](http://i.imgur.com/CtDkHu6.jpg)
2 port boost solenoid assembly. £10 plus post
![](http://i.imgur.com/UtZjVWk.jpg)
![](http://i.imgur.com/8CCY6sd.jpg)
![](http://i.imgur.com/Jmn1sgH.jpg)
![](http://i.imgur.com/ncOxiOK.jpg)
Facelift STI interior doorcards £7 each, All 4 for £20, good condition, need a clean from garage dust.
![](http://i.imgur.com/zLApoNh.jpg)
Starter motor - GWO - £15
![](http://i.imgur.com/c7ZQ7zW.jpg)
stock V4 headers, split but complete, excludes up pipe, £10. Collection only due to weight
![](http://i.imgur.com/2Y6BGp8.jpg)
Pre facelift Alloy bonnet - £50
![](http://i.imgur.com/BS4RUPt.jpg)
Short shifter - £20
