Sept 28, 2015 14:39:48 GMT
Thinking ahead to suspension/tyres after the 16v swap on the 205, i've decided to go for some proper rubber as i'll have a spare set of wheels with uniroyals for truly woeful weather and when it gets very cold..
Come across these Nankangs for a very good price, and it seems from a quick search they seem to be unsung heroes as far as fast road/trackday tyres. Anyone on here have any experience with these at all?
1989 Peugeot 205 XE - Gone to the scrappy in the sky, sad face.
1993 Mazda MX5
andy-v
i like cookies :D
Sept 28, 2015 15:19:38 GMT
had some on a k11 micra, few years ago, just day to day use,was on there car when bought, decent tread, taken off when scrapped, still with decent tread
Sept 28, 2015 15:59:03 GMT
I've run these on all kinds of things. They are good for the money but obviously they don't work miracles. The best of the "budget" tyres IMO.
Ignore me, I missed the -R
Last Edit: Oct 4, 2015 12:00:22 GMT by cobblers
Sept 29, 2015 11:15:36 GMT
Main problem is most of the tyres available for my wheels are 'eco' tyres, nothing performance orientated so hoping these are a decent shout as they're a fair bit less than r888's which I really can't justify!
1993 Mazda MX5
Nankang NS2-R TyresChasR
@chasr
Club Retro Rides Member 170
Sept 29, 2015 18:57:03 GMT
I doubt most of you peeps have had NS-2Rs although I stand to be corrected and apologise if I am wrong. They are not cheap for sure; OK compared to a Toyo R1R they are cheaper but certainly not road tyre cheap. These are quite a different beast to the NS-2s . These are a track based tyre, with a DOT R compound. It's aimed to go against tyres like the Yokohama AD08R, Toyo R1R and Federal 595R In comparison to Uniroyals these are awesome. They are also better IMHO than almost any road tyre. A few peeps have said their lap times on track days have slayed road tyres with the NS-2Rs on. On oldish well treaded Toyo T1-Ss the RST used to wheelspin in second in the dry and third in the wet. It will not only wheelspin in the wet if the tyres are not warm in 3rd (a motorway trip or pressing on cures this) and attempt to spin less in the dry. I reckon I can push them harder than I am TBH! Are there downsides? Sure 1) Being a track biased tyre they are more expensive than other tyres. On my RST in 195/50R15 I paid £75 fitted per tyre. To put that into context a Michelin PS3 would have been £60 which I was seriously considering going with. I understand that without fitting they are close to the price I paid fitted due to their increasing popularity. 2) In extreme standing water they are interesting! Not quite R888 bad (but bar going to slicks not many things are!) however and on damp ground they are surprisingly surefooted. Granted I avoided most wet puddles on the way back from the very wet RRG but my friend in his Mitsi 3000 GTO 4x4 was surprised how planted my car was when he was struggling to stay on my tail! 3) They are a little noisy ; again not R888 bad but not far off what a budget tyre is. I am however running zero insulation in the RST so that is subjective! 4) They don't last long! I have the street compound on mine and if I am honest I have driven the car far harder than I could previously and surprised people with what the car can do, even myself! The Streets are meant to never die on track but do require warming. They are not terrible when cold however; probably on a par with a road tyre but to get the best they do love heat. The Soft tyres are better here but dissapear before your eyes. 5) A trait of any DOT R tyre I have had (I have had Toyo R888s previously) is the increased width over the equivalent road tyre. On my RST I had to redo the front axle (remove the 5mm spacers to clear the brakes and then change the brake setup). It previously used to only kiss the front wheel arches, and with the NS2-Rs it went to practically tearing chunks out of them upon seeing a bump in the road! I shall let peeps know what these are like on a trackday, I have hoping they slay the R888s ; I could overheat the R888s with enough laps (15 mins of the 'ring GP circuit). I'm debating getting these for the Clio but I'll probably chicken out and get some Michelins or Contis. If you think I am lying, here are other opinions jackmorris: www.pistonheads.com/gassing/topic.asp?h=0&f=18&t=1403755&mid=0&nmt=well+someone+had+to+try+them.Nankang+ns-2r+%2B+520hp+car+%3D%3F%3F%3FAnd now some shots of mine :
Last Edit: Oct 1, 2015 22:46:55 GMT by ChasR
@chasr
I'm going on a Pistonheads trackday. If I take the Escort I'll let you know how the car behaves. My previous benchmark is my 205 on both R888s and Toyo CF1s in addition to my Clio around Castle Combe on Contis up front and Toyo T1-Rs on the rear.
Perfect response chaseR, just the info i was looking for! Price wise for the 'street' compound they're a good 30-40 pounds cheaper than R888s so I'm happier to try them at that price, considering i have spare wheels for RRG levels of water.... Came across that pistonheads topic which is persuading me more to go for them! Let me know what you think on the trackday
1993 Mazda MX5
Oct 13, 2015 22:35:42 GMT
How does the Yokohama AD08R and Kumho V70 compare in price?
Might be worth looking into as well.
Click picture for more
@chasr
Oct 19, 2015 20:05:02 GMT
Both of them are more expensive. IIRC the AD08Rs were close to £100 over the NS-2Rs. V70s are more like £130. I don't know of the V70as that well but I do know that the AD08Rs are meant to have the edge over the NS-2Rs.
@ettorbugatti, what experience have you had of track tyres? I'm toying with getting a set for the Clio now that shall be doing track duties for a while until I sort the Escort out more (oil surge being the main one).
Oct 19, 2015 23:22:16 GMT
nope, AD08R can be had for about £62 in 195 50 15 iirc!!.
Oct 19, 2015 23:25:36 GMT
correction, camskill have them at £56!!
no contest, ad08r ftw!!
its the ao48 race/rally tyre thats over £100 a corner in a 15"
Sadly they don't do the AD08R for 14s (sorry should have mentioned). Shame as they were one of the first I considered!
Looks like i'll be going for the Nankangs, will have to report back when my 205 gets back on the road someday....
1993 Mazda MX5
correction, camskill have them at £56!! no contest, ad08r ftw!! its the ao48 race/rally tyre thats over £100 a corner in a 15" That's well expensive! I can get them delivered to your door for £48 each
Specialist Bodyshop & Fabrication Classic, Retro, Prestige & Custom Small Repairs to Concours Restorations Mechanical Work Vintage to Modern
Oct 27, 2015 10:01:06 GMT
1) Being a track biased tyre they are more expensive than other tyres. On my RST in 195/50R15 I paid £75 fitted per tyre. They would have been £55 fitted with us. Some people seem to charge the earth for tyres!
@chasr
Oct 27, 2015 12:34:51 GMT
Your price seem cheaper than Camskill and MyTyres even when fitted! It shall be something to bear in mind.
Oct 27, 2015 12:38:00 GMT
We can ALWAYS beat MyTyres, Camskill and Tyre Leader etc on delivered tyre prices. Can't necessarily beat their delivered including fitting, but we're often there or thereabouts.
@chasr
Oct 27, 2015 12:48:33 GMT
Your price seem cheaper than Camskill and MyTyres even when fitted! It shall be something to bear in mind should I be in the area
Oct 27, 2015 21:01:44 GMT
correction, camskill have them at £56!! no contest, ad08r ftw!! its the ao48 race/rally tyre thats over £100 a corner in a 15" That's well expensive! I can get them delivered to your door for £48 each the yokos? feck! might have some for next year's hooning if so! what are you like on 235 45 17 premium tyres?
That's well expensive! I can get them delivered to your door for £48 each the yokos? feck! might have some for next year's hooning if so! what are you like on 235 45 17 premium tyres? For Michelin Pilot Sport 3, which I run on all of my normal use road cars, you'd be looking at £57.93 each delivered
