Sept 26, 2015 12:54:08 GMT
Hi guys, found a cool set of wheels. My pcd is 5x114.3 and the centrebore is 70.3
The wheels are 5x114.3 with an 85mm centrebore.
Does anyone know if spigot rings are availible in this size? I've had a look on ebay and some sites that specialise in spigots but haven't found anything.
Also - are there any wheel courier companies that come recommended?
Thanks guys
niwid
Sept 27, 2015 17:41:14 GMT
85 is an odd centrebore, best betbwpuld probably be to get someone to turn some on a lathe for you
May I ask why you want spigot rings? The only thing they are good for is making it easier to fit the wheel. If you don't mind a bit of hassle when changing a wheel I wouldn't bother with them.
Sept 28, 2015 5:53:36 GMT
Thought that some wheels are actually centered directly by the hub rather than being held in place by the bolts?
That the hub take the strain off the bolts?
Rich
Club RR Member Number: 160
Spigot rings and wheel fitmentRich
@foxmcintyre
Club Retro Rides Member 160
Sept 28, 2015 7:02:49 GMT
Thought that some wheels are actually centered directly by the hub rather than being held in place by the bolts? That the hub take the strain off the bolts? Not this again.. All the spigot does is ensure the wheel is dead central while the wheel is bolted on. Some cars are bolt-centric rather than hub-centric. What holds the wheel on isn't the shear force in the bolts at all, there is only undue stress exerted on them if they are not tight enough, what holds the wheel in place is the tonnes and tonnes of clamping force creating friction between the hub face and the wheel by the bolts. So there you go. You can get away without spigot rings on the condition the wheels aren't sleeve nut or uni-lug type.
niwid
Sept 28, 2015 8:21:33 GMT
I used to work for an aftermarket wheel company, and most people seem to believe that the spigot ring is structurally important. Not just Joe Blogs on the street, but some of the most affluent people in the industry would refuse to fit wheels without spigot rings due to 'oh it won't balance and will vibrate and the bolts will snap'. What people don't stop to think is that spigot rings are made out of the cheapest, flimsiest plastic around. If that was literally stopping the wheel moving around then it wouldn't do a great job.
As Rich said, if the wheels are not located with taper or radius seat nuts/bolts then spigot rings are used to make sure the wheels are centred, but as soon as it's bolted onto the car, none of the force exerted onto the wheel is passed to the spigot. The wheel is held in place by friction
Dez
Club RR Member Number: 34
Sept 28, 2015 8:46:54 GMT
what they all say. the idea hubcentricity is actually a fairly new thing. it only really started happening when the majority of cars went to wheel bolts rather than studs and nuts (as a manufacturing cost-cutting exercise). its rare ot see a pre-70s car with a spigot. as noted its only to to make it easier to line up the wheel bolts. back when cars had studs, it was actually fairly rare for them to have a hub spigot as well, as the studs provided that function.
in engineering terms, the wheel bolts/studs should never see a shear force. if they do, they're not tight enough. the wheel is held on by friction between the hub face and wheel generated by the tension in the bolt/stud.
the only time you actually NEED a spigot is when the wheel isnt being centred by anything else, e.g' the taper or radius on the bolt/nut, or if you are using wobble bolts. still, it didnt stop quite a few manufacturers both OE and aftermarket specifying sleeve nuts with no centre spigot...i guess they though that as its studs by the time youd got 4 or 5 nuts on any play left would be so small it wouldnt effect balance.
there is also quite a few notable examples of cars that have neither studs nor a hub spigot. like pretty much every aircooled VW ever made... and they made *quite* a few of those without the wheels falling off.
Last Edit: Sept 28, 2015 8:51:35 GMT by Dez
Sept 28, 2015 16:59:50 GMT
Brill - that all makes wonderfully perfect sense, I stand both corrected and educated. Cheers guys
Sept 30, 2015 16:37:21 GMT
In that case Dez, is there no issue running those cheaper non hub centric spacers over the more expensive hub centric ones?
'73 Commer Campervan under full restoration, '83 VW T25 Doka under partial restoration to become rolling project, '04 Saab 9-3 Vector Sport modified and certainly not finished...
Dez
In that case Dez, is there no issue running those cheaper non hub centric spacers over the more expensive hub centric ones? Yep, as long as the above caveats are followed it wont make any difference.
stevek
Yorkshire and The Humber
Oct 16, 2015 22:04:36 GMT
As the subject is being discussed can I ask a related technical question please? Yes, OK thanks... I fitted Peugeot 205 GTi wheels to my Porsche 924. The original Porsche wheels used radius seat bolts and center spigot mounting too. The after market alloys I was replacing used 60 degree taper bolts but no spigot rings used, these were just centering on the taper bolts. The Peugeot wheels use flat seat shank bolts when fitted to a Peugeot, to fit them on the Porsche I fitted some adapters in the flat seat bolt holes to allow use of 60 degree taper bolts. I also used spigot rings as the wheels had already been machined to take them. So my question is; did I really need to use spigot rings? The potential problem is that adapters may have a TINY bit of lateral slack/inaccuracy as they aren't a machine fit, but apart from that the taper bolts will center the wheel up. Do you think that this fitting would center the wheel accurately enough without using a spigot ring? It would mean I could run another set of Peugeot/Citroen wheels which don't have the recess for spigot rings. -Steve- PS. These pictures may help to understand the adapter/inserts I used to fit the taper bolts...
Last Edit: Oct 16, 2015 22:19:57 GMT by stevek
Oct 16, 2015 23:07:17 GMT
Hi, if your using tapered nuts/bolts to centre the wheels on the studs you don,t need spigot rings.
Colin
Dez
Oct 16, 2015 23:39:30 GMT
Assuming they're a reasonably tight fit in the holes you'll be fine without spigots.
Out of interest where are they from and what size is the shank? A set of those might solve some issues I have with missing seats on some wheels I have.
stevek
Oct 18, 2015 11:26:01 GMT
stevek
Oct 18, 2015 14:52:35 GMT
In that case Dez, is there no issue running those cheaper non hub centric spacers over the more expensive hub centric ones? Yep, as long as the above caveats are followed it wont make any difference. I am learning a very valuable lesson here. So with what you are saying, I can use cheapo 30mm spacers on my Merc as long as I can get some 30mm longer wheel bolts? I would of thought they were available cheaper than the £100 I've been quoted for hubcentric bolt on spacers?
