Sept 25, 2015 15:04:45 GMT
There are three fuel lines. Feed, return and breather running from the petrol tank. Mine are corroded.
Anyone got info on best materials and way to replace the steel fuel pipes from the tank?
I am thinking of nylon tube/pipe and appropriate fittings.
Need to know the right sizes (internal diameters) suppliers and recommendations from those wise experienced folk what knows for sure and/or has already done it.
Sept 25, 2015 15:05:58 GMT
Forgot to mention that it's a UK version.
Sept 29, 2015 13:01:07 GMT
Can't answer your question but does your Fuel pump hum like a swarm of bee's most of the time - noise from NSR? Ours does and has since we got it - told it was the system purging out bad things and it is perfectly normal!
Last Edit: Sept 29, 2015 13:02:27 GMT by SmokeEm
Can't answer your question but does your Fuel pump hum like a swarm of bee's most of the time - noise from NSR? Ours does and has since we got it - told it was the system purging out bad things and it is perfectly normal! No it's not, mine is perfectly quiet bar the short priming when you first start it in the morning. That said, I've heard about noisy fuel pumps from other Accord owners. Maybe your fuel lines have swollen from the inside due to rust and are causing the issue. Maybe the pump is on its last legs. Either way, you'll have to scrap your car since these are now going through the "can't justify a £100 repair on a £300 car" -phase.
Can't answer your question but does your Fuel pump hum like a swarm of bee's most of the time - noise from NSR? Ours does and has since we got it - told it was the system purging out bad things and it is perfectly normal! No it's not, mine is perfectly quiet bar the short priming when you first start it in the morning. That said, I've heard about noisy fuel pumps from other Accord owners. Maybe your fuel lines have swollen from the inside due to rust and are causing the issue. Maybe the pump is on its last legs. Either way, you'll have to scrap your car since these are now going through the "can't justify a £100 repair on a £300 car" -phase. Not likely, my Wife loves it. She clocked up 50k miles in it last week so still very low miles. It's been like it over a year now so will just leave as is.
