I'm selling this 190e because it doesn't get used. I bought it in May as a runaround and have hardly used it so there's no point in keeping it. It has MOT til April 2016 and a folder full of service history and the original handbook.
I gave it a service soon after buying it, spending over £120 on parts, with paperwork to prove (Plugs, leads, air filter, oil filter, oil, fuel filter, distributor cap, rotor arm, coolant temp sensor).
The car is in good condition. There is absolutely no rust underneath and it has never been welded. Runs spot on and drives well. And the electric aerial still works! Comes with 8 hole alloys with good tyres, Kenwood CD head unit, and alarm/immobiliser.
OK bad points -
Vinyl door cards are doing the usual thing and warping at the top.
Rear windows have stopped working.
Central locking stopped working.
Paint shiny but could do with a polish to remove fine scratches.
I've investigated the 'exhaust leak'. Turns out there's a very small amount of fumes leaking from the manifold gasket or downpipe. It leaks when started from cold, but seals after 30 secs as it warms up. No funny smells at all.
£800 and its yours. Car is located in South London.
OK bad points -
