Aug 31, 2015 17:08:43 GMT
Got this knocking about the yard, the owner bought it on impulse because he thought the engine would make a good doner for something retro. I've been trying to find info on the net of how swappable they are but can't really find anything. It's not so much the fitting it but getting it to run, do these have any complicated immobilisers or management that might make using it as a doner awkward? Just trying to get some idea of what would be involved in getting it running before I put the effort into pulling it all out
squonk
Aug 31, 2015 17:21:57 GMT
What year is it? Has it got the normal ignition key or the electronic one? Either way it will have an immobiliser and an ECU, its just that the electronic key version is more complicated to sort out.
Aug 31, 2015 17:25:02 GMT
Aug 31, 2015 17:28:01 GMT
Cheers for the links, i'll check them out in a little
The cars a 1997 but hadn't really paid any attention to the key, i'll have a look tomorrow
sowen
Club RR Member Number: 24
Aug 31, 2015 18:59:38 GMT
Just search for OM605, you'll probably want a mechanical pump of an earlier single cam OM602, or the Ssangyong Musso 2.9td which uses a suitable mechanical pump too. Downside of the mechanical pumps is that they flow less fuel as standard, but they can be modified by specialists to throw a lot of fuel into those Mercedes diesel engines
benjy_b
Yorkshire and The Humber
Aug 31, 2015 18:59:47 GMT
Compound charged OM605 fitted to a KE70 Corolla: click here
2005 Subaru Forester 2.5XT 1999 BMW E36 318i Touring with OM605 Mercedes Engine 1996 Lada Riva with Honda S2000 Engine
Aug 31, 2015 21:11:40 GMT
Sounds promising, if I can't get it to work on the original management at least there's a back up option of switching to a mechanical pump. Cheers for the help lads That corolla looks amazing!
