tom83
Aug 30, 2015 18:08:44 GMT
Just noticed this, not sure if its always happened. But when I apply the handbrake the brake warning light (circle with the lines around it) comes on. Hasn't been on at any other time. Is this usual? If not any ideas? No leaks and the fluid level it at max.
Faulty connection on the reservoir cap is my current line of thinking.
Aug 30, 2015 18:36:59 GMT
totally normal. it's just warning you the handbrake is on.
Aug 30, 2015 18:39:54 GMT
Ditto, it was faulty before, now it's working properly.
tom83
Aug 30, 2015 19:04:42 GMT
It's got a parking brake light too, which is what I found weird.
scimjim
Club RR Member Number: 8
Aug 30, 2015 19:23:09 GMT
many cars use the handbrake switch as a bulb test for the fluid level circuit (MOT test requires it to work if fitted and lifting the bonnet every time is a bit laborious
niwid
Aug 30, 2015 19:32:04 GMT
As said, all cars do it Don't worry though, I remember panicking because when I turned the ignition key on my first car, all the warning lights came on, but went out when I started the engine. I also thought my dipped beams were broken, so drove with only sidelights or full beams for weeks. I didn't think to pull the stalk towards me. Oh, and when I got towed for the first time, I thought my brakes were broken as they required so much effort to operate. Funnily enough they fixed themselves when I turned the engine on again
tom83
Aug 30, 2015 20:24:02 GMT
Cheers all, that's one thing off the list .
