I'm after a pair of 13" steels in mini fitment, or viva or minor are the same I believe?
Basically I've fitted a K series subframe to my mini and am running metro wheels on the front. Because of the wider track I need wider rear wheels. So I'm after a set of 13" steels I can band to match the width to fill my arches I need to run for the front. I don't really want to run the massive Watson spacers on the back, and if I got my 13x7 mini lights re drilled to fit the metro PCD then it would end up far too wide!
