Aug 13, 2015 16:39:28 GMT
Hi all!
New to this forum and have just bought myself this little thing of beauty for some fun!
and need a little advice / help from you guys as to what bike carrier we can use on the rear of this thing?? Anyone have one they bought and can advise? We cant put a spare wheel rack on as the bikes will hang right out from the side of the van, and cant have a roof rack either.
jgtr
Aug 13, 2015 17:58:30 GMT
How many bikes?
Personally I'd look at having a bracket manufactured that goes on behind the spare wheel, add some strengthening plates to the door, job done.
Maybe a bar that comes up and the goes across the rear with 2 arms for the bikes, that way you can still open the doors. Use a strap to tie it to the ladder for some extra stability.
Last Edit: Aug 13, 2015 17:58:58 GMT by jgtr
jgtr
Aug 13, 2015 17:59:46 GMT
Or could move the number plate and bolt it on using the wheel bolts
EmDee
Committer of Autrocities.
Club RR Member Number: 108
Aug 13, 2015 18:09:27 GMT
Or you can get a towbar (which may come in handy for towing other purchases), and there are bike carriers that fit to them.
Aug 13, 2015 18:53:42 GMT
Aug 13, 2015 21:37:17 GMT
thanks all for your tips - its a bit of a tricky one because the position of the ladder and the spare wheel means bolting to either of them wont work as the bikes will stick too far outside the dimensions of the van width.
But towbar rack may be the answer - sadly the most expensive one of course!
Aug 13, 2015 23:30:21 GMT
Hi, If there is no roof rack why is there a ladder? Although it does provide a good attachment point. How about devising a bracket that will hold the bikes vertically instead of horizontally? This will get round the width issue of it on one door.
Colin
<<< i've a GMC safari - it also has the ladder on the rear rhs door - like them all it's just for show as the roof is fibreglass
i just lay my bike inside the van on the bed. simples!
<<< i've a GMC safari - it also has the ladder on the rear rhs door - like them all it's just for show as the roof is fibreglass i just lay my bike inside the van on the bed. simples! That would be a great solution, sadly I'm incumbered with a number of children who need to occupy the seats, so thats also out!
MiataMark
Club RR Member Number: 29
Remember that if you hang them off the back you'll probably need a light board etc anyway.
Depends on the number of bikes really it sounds like you might want to carry a few, a tow-bar mounted one is probably best for >2 bikes.
What about getting a roof bar carrier (the tray the bike sits on, or the bits that Bruce shows above) and mounting it vertically on the door ladder, you'd need to strap from the cross-bar to the ladder to prevent the bikes moving sideways. You'd be able to use the doors as well and wouldn't block the lights, number plate etc.
jgtr
thanks all for your tips - its a bit of a tricky one because the position of the ladder and the spare wheel means bolting to either of them wont work as the bikes will stick too far outside the dimensions of the van width. But towbar rack may be the answer - sadly the most expensive one of course! Just offset the rack so it sits in the middle
MiataMark
like this...
Aug 15, 2015 13:02:32 GMT
