Model:Mitsubishi mk1 pajero 2.5 diesel intercooled manual
Year:1989
Mileage: 180ish vehicle 130ish engine
MOT:Jan next year or 12months depending price
Price:£1900 can remove winch and tyres to bring down the price
Here is my 1991 mk1 pajero 2.5 td intercooled
Engine has just had
Timing belts/bearings with all front and rear oil seals
Clutch 3 piece, clutch master, ring gear and starter, alternator, all Blue print so good quality, recent full service as well
It has a mk2 shogun rear axle fitted so it has the massive 9" ring gear and air locker, ratio is 5.28 great for offroad crawling and turns around 3000rpm at 70mph which it seems to love, same ratio up front as well
Also it has the factory fit Mitsubishi engine driven PTO winch which is ridiculously powerful and quick depending on which forward gear is selected, I have uprated the engagement cables well over strength and also one piece of the two piece driveshaft, the winch has just had the main internal load bearing replaced, will need a new winch cable unfortunately
Currently fitted are 33" 255/85/16 BFG mud m/t around a year old all hold air
It is a little rough around the edges but nothing major, I drove it daily last year doing 12k with no problems it does around 28mpg on the 33s
It has electric windows with the drivers being one touch
Price is £1900 as it sits
But I could take the tyres and winch off to make it cheaper if needed
Viewing recommend 10mins from Jn26 of the m1
Regrettably selling due to wanting a new offroad project, if you have a suzuki sj soft top in okayish condition I deal could be arranged
Any questions just ask
Year:1989
Engine has just had
