Jul 21, 2015 10:03:39 GMT
I have recently taken the front (only front discs) apart on my Hillman to tidy them up and paint them. While they were apart I thought I'd just blow out any cr*p in the lines with an airline, to which I found I couldn't get any air through it!!!! I'm guessing where it was stood for so many years before I got it that the brake fluid has gunged up? And if they're anything to go by, I'm guessing all the brake lines will be blocked! Anyone know how I can clean it out, what to use, etc.... Or would it be easier to just replace the whole lot of lines? Cheers Craig
Jul 21, 2015 12:22:33 GMT
I would replace the lot tbh, a roll of copper nickel pipe isn't expensive.
colnerov
Jul 21, 2015 15:19:01 GMT
Hi, it could also be that the flexible has collapsed internally.
Colin
bortaf
Jul 21, 2015 19:35:42 GMT
What way was you blowing? there may be a 1 way valve in the brake line Personly i never use an air line to blow anything out a brake line, you just probably blew moisture into them, just empty then top up the master with fresh fluid and pump it through that way, THE only time i use air on brakes is if i have to pop out a caliper cylinder.
R.I.P photobucket
v8ian
Jul 21, 2015 19:47:03 GMT
Shame you cant get different colour brake fluids any more, normally the choice was red yellow or green. made for bleeding brakes with new fluid a doddle,
Jul 21, 2015 20:12:18 GMT
id fit new lines , worth it for the peace of mind knowing its all fresh and safe
kunifer is the one to go for , not copper
Jul 21, 2015 23:46:34 GMT
Thanks for all the help guys I'll look at pricing up some new pipe! And I blew through both ways, I cleared the passages in the caliper casting with a length of welding rod and blew out the rest, which was all this old stinky gunky cr*p My plan was to blow out the gunk and clean it out and start afresh but seems I'll be starting afresh properly now ?
Last Edit: Jul 21, 2015 23:47:01 GMT by code109
Jul 22, 2015 18:09:18 GMT
Jul 23, 2015 13:53:03 GMT
You sir are a legend!!!!
Last Edit: Jul 23, 2015 13:53:15 GMT by code109
Jul 25, 2015 10:26:07 GMT
beal.org.uk for the pipe and fittings
