H reg 205 Cherry red ph2 gti rolling shell - North Yorkshire
Time to admit i took too many projects on and some are never going to get done, so here is one of them. There is lots of good bits on this car, would make an easy project for someone with the required spares. The bits on the car include; Rolling with all suspension, steering and brakes Power steering rack Good ph2 steering wheel All exterior trims intact and inplace, some red strips missng Complete rear beam and it bounces Body and engine wiring still in place Engine bay immaculate Fuel tank, pump and pipes all present and correct I have the full V5 in my name, it was last on the road in 2009 with 135k - one key fits the ignition, doors, bootlid and fuel cap which is a bonus Things to note; Dented O/S/F wing Drivers footwell needs welding Passenger front window perspex Registered 02/11/1990, please have a look through the pictures and let me know if you have any interest in it, or if you have any further questions. Thanks for reading, Ben
Last Edit: Aug 16, 2015 14:52:37 GMT by Deleted
Jul 17, 2015 18:35:20 GMT
To the top with a few new pictures
jgtr
Jul 19, 2015 13:48:37 GMT
Id be interested in the looms if you were to break it, are you sure it's a P2 as it has grey dash?
Jul 19, 2015 17:13:42 GMT
Thanks for the message, yeah its also got what looks like grey exterior trims too, you can just see on the interior pic the door hinges - that coupled with the power steering rack and rear lights made me pretty sure, mainly the door hinges though as they are from factory welded. Where abouts are you? i may be able to get the lot to you cheap and you could keep the loom and sell the rest?
jgtr
Jul 19, 2015 18:54:46 GMT
I'm in Essex, miles away from you :-(
I'm in need of a phase 2 loom, but I've got the early type apparently without the round connectors for the door wiring, I also have the earlier hammer in type hinges, b*****y confusing!!
Aug 11, 2015 12:00:39 GMT
Giving this a bump, its still here - such an easy project... would make a 2k car with a few bits.
gibski
Kinda New
Will the Vtec Panda Make RR hillclimb this year???
Interested in this can you drop me your number 07717706024
