Evenin'
Due to change of plans i now have this beast of an engine for sale.
I was going to originally use this to replace the truly terrible transit diesel engine in my Chevy C1500 Truck.
I removed these myself from a 1994 Toyota Celsior (Imported LS400).
It pulled strong and ran like a champ on the 600mile journey home from Newcastle.
Car had done around 180,000KM
![](http://i147.photobucket.com/albums/r296/woodoouk/1UZ%20For%20Sale/IMG_20141215_193814988_zps6rub74eo.jpg)
![](http://i147.photobucket.com/albums/r296/woodoouk/1UZ%20For%20Sale/IMG_20141119_164637921_zpscqrrt5rs.jpg)
Also free (with the engine) book! its a really good, clear guide how to finish the wiring.
![](http://i147.photobucket.com/albums/r296/woodoouk/1UZ%20For%20Sale/IMG_20150217_201350209_zpsrsexwp5a.jpg)
Complete Engine and box loom and ECU, with all the ancillaries. (alternator is seized though)
£300
I have already been through the loom and got it ready to what ever you like and labeled up everything needed. (Kickdown switch, Sport mode switces etc.)
Included with the engine is the Radiator, the exhaust, Propshaft and the Shifter out of the lexus. I have also converted it from the Hydraulic cooling fat to an idler.
![](http://i147.photobucket.com/albums/r296/woodoouk/1UZ%20For%20Sale/IMG_20150629_193159690_zpsgznifhcq.jpg)
![](http://i147.photobucket.com/albums/r296/woodoouk/1UZ%20For%20Sale/IMG_20150629_200818160_zpsjpshmwsd.jpg)
![](http://i147.photobucket.com/albums/r296/woodoouk/1UZ%20For%20Sale/IMG_20150629_200752090_zpsizif9lzm.jpg)
![](http://i147.photobucket.com/albums/r296/woodoouk/1UZ%20For%20Sale/IMG_20150629_200602019_zpsxld1hwg4.jpg)
![](http://i147.photobucket.com/albums/r296/woodoouk/1UZ%20For%20Sale/IMG_20150629_200432556_zpsccft4g26.jpg)
![](http://i147.photobucket.com/albums/r296/woodoouk/1UZ%20For%20Sale/IMG_20150629_200401194_zpsk2epi1yd.jpg)
I have spent a lot of time and effort getting this engine ready to go into my truck. I have all these bits available too. Willing to do a deal if you take them with the engine.
Oil filter relocation plate with AN fittings. The Oil filter on a 1UZ sticks out quite far, this will solve this issue when used with a remote oil filter.
£25
Another relocation plate, this one has an extra fitting for an oil pressure sensor. this one was from Excessive engineering in the USA, this one uses a o-ring instead of a gasket. However the threads are pretty curse word and I would suggest re-tapping them.
£25
Brackets for using a B&M ratchet shifter with the Toyota A341e Autobox, (these came from MVAutomatics in Australia)
£40
![](http://i147.photobucket.com/albums/r296/woodoouk/1UZ%20For%20Sale/BampM%20to%20suitToyota%20Selector%20Brackets_zps6rw4swdw.jpg)
The engine also has a choice of front orrear sump.
If you just want a sump that will be £75 for the front bowl or£100 for the rear bowl
![](http://i147.photobucket.com/albums/r296/woodoouk/1UZ%20For%20Sale/post-7786-0-24323800-1418005483_zps6llkx8ef.jpg)
All items in South Wales willing to post some of the smaller stuff.
£300
£25
£25
£40
