Ok my car priorities have changed so its time to sell the 2 datsuns first up is the Stanza.
Its a 1.6GL, 4 door saloon with 46000miles and MOT till August. It runs faultlessly and goes very well for a 1.6. Ive already extensively welded this car but it will require more on the Drivers side rear arch/sill. Zeibarted from new so the floor is still in a decent condition. The bottom of the drivers side doors are rusty along the bottom. Will also need discs and pads as the discs are warped. Will be on standard wheels. £400
Next up is the Bluebird,
1.8GL 27000miles, MOT has just expired but cant see it needing much apart from a backbox. Runs good, idle a bit lumpy and not the best on overrun but took it on a 250mile round trip with no issues at all. Starts on the button. While the car will require NO welding its starting to show its age at a few bits, a few scabs over the car would require attaention if you wanted to use it everyday. I was in storage over last winter so hasnt got much worse.
Its leaking gearbox oil out the output shaft but its not much, only had to top up once. £1000.
I think i will regret doing this but need to cut down.
