Model:Peugeot 305
Year: 1986
Mileage: 98,000
MOT:October 2015
Pics: Below
Price: £800
Contact details: PM
1986 Peugeot 305 SRD estate. 1 Of 3 left according to the usually howmanyleft.com
1.7 XUD Diesel engine. Lucas pump.
Just over 98,000 miles with a full stamped service history. Also comes with instruction booklet for original stereo.
Work recently done shown below. All receipts will come with the car.
Genuine Peugeot Clutch kit and cable.
Genuine Radiator from Elim Peugeot in Llangefni.
Genuine Peugeot Disks and Pads come with the car.
Comes with passenger rear door skin. Current one isnt too bad, just snapped a skin up for the future.
Part:
Fitted:
Cant show the clutch fitted, but it is! Receipt for £300 worth of labour too.
Things of note:
Both rear shocks are misting. The back end however, rebounds and settles as it should under bounce test conditions. The temp gauge does'nt work, but I do have a new sender to try (car has done over 400 miles in one shot, on a baking day, with the old radiator without any cooling issues, so the temp gauge isnt hiding any issues).
There is an intermittent squeak from the rear passenger side over bumps. Sounds like the spring to be honest, but people have suggested rear arm bearings. I don't think theres any adverse camber though (see below).
Needs a good clean inside.
The rear arches have been welded and painted, and its not the best job though it is solid all round.
There is a bit of surface rust along the bottom of one passenger rear door.
Drivers seat bolster is worn through and holed.
I've gone out of my way to mention anything negative that I can think of in relation to the car, which probably makes it sound a lot worse than it is. Its a solid, well cared for, 29 year old car that runs as a daily driver without complaint.
Car starts, drives and stops as it should. Runs like a train and pulls like a dream.
Ideal surf wagon base? OMGSCENE.
Price is £800. There a lot more than that been spent on it (by Me), but don't expect to see it all back.
Questions by PM if you have any. No Swaps.
Cheers all.
Year: 1986
Mileage: 98,000
MOT:October 2015
Pics: Below
Price: £800
Contact details: PM
Part:
Fitted:
Things of note:
Cheers all.
