I know it's an odd question this time of year, but what antifreeze do you use in your alluminuim engine?
Dropping a new Rover V8 into my TR7 and I need to buy some, what do you recommend?
Thanks,
Steve
May 25, 2015 10:21:25 GMT
All you need to do is look on fleabay and search for antifreez for Datsun and see what the recomend .In my mercedes i have Coma Extream G48 with de-ionised water 50/50
bortaf
May 25, 2015 12:21:37 GMT
I use the long life red in the P100 but older style blue in anything with BRASS rads, the red stuff only likes alloy parts not brass.
R.I.P photobucket
May 25, 2015 13:05:39 GMT
Evans waterless.
May 25, 2015 13:32:18 GMT
Just as long as you have no leaks. It ain't cheap...
envoycdx
North East
I need my Mojo back!
May 25, 2015 14:12:29 GMT
How well does that stuff work? And if you do spring a leak can you use water/ coolant mixtures to get you home?
envoycdx
North East
May 25, 2015 14:14:19 GMT
However, I'm currently using Bluecol universal to top up the Vauxhall stuff.
May 25, 2015 15:30:46 GMT
Just as long as you have no leaks. It ain't cheap... Less chance of a leak as there is no pressure in the system How well does that stuff work? And if you do spring a leak can you use water/ coolant mixtures to get you home? I haven't had any overheating issues since I put it in, Mixing with water would be a big big no no.
envoycdx
North East
May 25, 2015 15:49:06 GMT
Just as long as you have no leaks. It ain't cheap... Less chance of a leak as there is no pressure in the system How well does that stuff work? And if you do spring a leak can you use water/ coolant mixtures to get you home? I haven't had any overheating issues since I put it in, Mixing with water would be a big big no no. Handy to know, cheers!
