OK, its on a bike, but its a twin coil, 4 cylinder wasted spark set up.
Basically I've got hold of a zzr1100 that's been sat for a couple of years.
I've had it running but sometimes it will go straight off and run excellently, other times just cranks for ages.
The fuel is good, the carbs are clean.
If it won't start, if I remove one plug lead (any plug) and check for a spark with a spare spark plug, the engine usually fires straight into life, albeit on 3 cylinders.
This has happened on a too many occasions for it to be a fluke. Its wrecking my head! All I can assume is that I'm either discharging a coil that wasn't before, or making a good earth by grounding a plug to check for spark.
I'm going to go through the loom plugs and clean them, and also check the engine earth points, plus run an extra earth the coils just to make sure.
Any other suggestions?
