Wilk
PPPPPP....... You may know story ^
If you had realised there was no meat for the bbq you'd have known that you had to go to Tesco anyway, therefore there would have been no need to attempt to get the beer from the Middle of the room and so you wouldn't have knocked the charcoal onto the newly painted floor. You then wouldn't have thought of the bbq in the first place. Result!
Barbecue totally unplanned. Quickest way of getting rid of a slashed open bag of charcoal was to burn it. Weather not exactly barbecue weather, but that fire did warm up East Sussex a few degrees :-)
Sounds like a result all round mate.
Any excuse to burn meat where I live.
Sometimes no excuse needed.
People at work are wondering why I'm sitting here chuckling; mind you, people at work often wonder about me so no worries. A harrowing tale, well told, sounds a bit like a low rent Indiana Jones movie. Midas looks like a splendid fellow - shame he snores though!
17h01. Yesterday evening. Text message. " Isn't you courier coming to collect the grinder today?"
Not what you want to hear that time of the day ,having arranged so carefully and having taken the day off today.......
samta22
Stuck in once more...
Club RR Member Number: 32
Apr 27, 2016 10:15:45 GMT
Oooooh I hate it when that happens... hope it gets sorted
Apr 27, 2016 10:34:24 GMT
17h01. Yesterday evening. Text message. " Isn't you courier coming to collect the grinder today?" Not what you want to hear that time of the day ,having arranged so carefully and having taken the day off today....... Oh dear ...... Nearly as bad as having a courier turn up expecting to collect something that you know nothing about .......
Apr 27, 2016 11:08:28 GMT
This turned up. Pre twelve as arranged Needs to be in there Abra cadabra. All my watching Harry Pothead finally paid off. Answers on a postcard as to what levitation spell I used.....
Wilk
Apr 27, 2016 11:58:42 GMT
Expelliarmus obviously Or I'm sure Hermioni was able to make it rise.... If it's this version of Pothead you've been watching ?
Last Edit: Apr 27, 2016 11:59:15 GMT by Wilk
Apr 27, 2016 16:52:19 GMT
my money is on the that pallet truck and judicious use of wood off cuts up the kerb-ramp
or you designed and scratch built a magnetised monorail using a reclaimed fairground ride from dreamland margate and old surface plates
Last Edit: Apr 27, 2016 16:52:39 GMT by darrenh
v8ian
Apr 27, 2016 17:03:58 GMT
No obvious pinch bar marks on the floor, so, lots of pieces of steel bar rollers, or put on a sheet of 16swg sheet, a bit of oil and a good push
Last Edit: Apr 27, 2016 17:04:53 GMT by v8ian
Apr 27, 2016 17:43:20 GMT
Hopefully the lorry had a taillift ...... Or even better one of those mini forklifts chained to its rear end .....
Darkspeed
Club RR Member Number: 39
Apr 27, 2016 18:41:21 GMT
Antigraviartosovertherenowrus.
And don't knock over that precariously balanced 100 weight bag of opened Portland whilst you are ....
jpsmit
Apr 27, 2016 19:15:49 GMT
Oh for heaven's sake, clearly mag lev cunningly constructed out of used pallets and pheonix feathers, strategically deposited before the beginning of time to be just below the surface of the drive and the shed just for this precise moment. Easy peasy
Apr 27, 2016 19:28:31 GMT
Oompah Loompah slaves to pull it over rollers made by taking a gas axe to the local street light poles?
Apr 27, 2016 21:15:18 GMT
Sometimes it's not what you know,it's who you know. Big thanks to Peter Bourne at Gardenscape/ Bourne Amenity for sending up Gareth with the Telehandler....
At a quick glance,it doesn't look too bad. Needs a good clean to start off with. Mostly complete. Needs new belts which is pretty much a service item. Handwheel in front needs replacing. Motor that drives the table back and forth no longer there. Automatic down feed missing a couple of bits.Internal grinding spindle missing,but think I have a lead on that. Still a bit of a mystery machine. Made by Jones and Shipman, can't find a model number and haven't found the serial number yet. Also, have never seen another cylindrical grinder where the headstock drive motor is perpendicular to the chuck Think I might have to put up a Google foo challenge picture to see if any of you lot manage to find any info on it..... If I could find pictures of the missing down feed linkages,that would be awesome.....
You could always contact Jones and Shipman.
0116 2013000 Info@jonesshipman.com
Uk office Leicester.
Had sent an email already requesting further information and where to look for the serial number
Darkspeed
Apr 28, 2016 10:11:19 GMT
Sitting there as it does it looks like a big version of my Black and Decker valve grinder.
