encino
Apr 29, 2015 16:59:51 GMT
This Monza is currently on ebay fitted with a 24 valve motor and manual gearbox. The motor appears to be a 4.0 ltr, could this be a special unit or just a valve cover off something more exotic?
Ray Singh
More German exotica in my garage now
Apr 29, 2015 17:22:50 GMT
Could it be a Holden ?
Apr 29, 2015 17:24:35 GMT
4.0 from a Irmscher Senator. Cool conversion.
Last Edit: Apr 29, 2015 17:28:14 GMT by WillCarter
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Apr 29, 2015 17:25:40 GMT
They did a 4.0 Senator? That one completely passed me by then!
Apr 29, 2015 17:27:52 GMT
irmscher c40se? re bored/stroked monza/senator engine around 270bhp pretty sure there was a turbo or supercharger kit for these aswell, some one will now alot more though MonzaPhil ?
Apr 29, 2015 17:30:27 GMT
They did a 4.0 Senator? That one completely passed me by then! I edited because I thought a 4.0 was a more run of mill, turns out it's Irmscher only.
MrSpeedy
East Midlands
Apr 29, 2015 17:33:43 GMT
Ahhh, that explains it then!
Still, bloody nice though
Apr 29, 2015 17:39:56 GMT
Apr 29, 2015 18:34:30 GMT
That's been on EBay before, some time ago admittedly. They're using the same pictures as last time, Not sure if it really is a 4.0, could be just the cover?!
I'm not keen on the way they've patched the front suspension turrets, bit of a bodge! And the front shock top mounts are definitely not correct and don't even appear to be bolted to the turrets! Shonky!!
Apr 29, 2015 18:55:43 GMT
sure I have seen that car on here somewhere?
MonzaPhil
Think like a man of action, act like a man of thought
Apr 29, 2015 19:37:30 GMT
Friend of mine bought it last year but got made redundant to either sold it on or cancelled the sale.
If I bought it I'd only keep the engine which is definitely a 4.0 apparently.
Maybe the wheels.
I think this is all I know.
Sent from still on my honeymoon using proboards
This is now a clicky linky!
breng
Apr 29, 2015 20:11:17 GMT
Was'nt ther a 4.0 variant of the 12v engine? I am sure some went to South Africa.
Yep, those turrets look like they wanted to meet each other.
MonzaPhil
Apr 29, 2015 20:55:50 GMT
3.6 12v and 3.9 12v but the 24v was the 4.0. I think they'll go over 4 litres.
Sent from my 3.0 12v is thirsty enough using proboards
encino
Apr 29, 2015 22:40:30 GMT
What sort of power will this engine produce?
MonzaPhil
About 260hp which is plenty.
Easier to find in mainland Yerp though.
Sent from my place using proboards
encino
Apr 30, 2015 10:40:15 GMT
Whoever did the conversion may have done other mods like a limited slip diff and maybe suspension and braking mods, might make a awesome trackday car when welded up.
MonzaPhil
Apr 30, 2015 10:53:56 GMT
Agreed. It looks quite low and an LSD is a sensible swap if not already in there.
A few extra horses must make a world of difference but it's not a GSE so not one for my collection.
Not sure what the deal is with those strut tops but if they're loose it would just fall off the road. The turret repairs aren't the nicest to look at but if they are strong then it's not a problem. I've seen worse patches, and bigger.
As I said, I'd pull the motor for something else and drop a 12v back in there.
That said, I'd like to explore horse increasology on a 12v before going down the "easy" route.
bstardchild
Club RR Member Number: 71
The 4.0 Litre engine is a nice lump but not without problems
Head gaskets are very difficult to find and the land between the bores is much smaller than a 3.0 (engine was bored and stroked)
The other issue is they had a hotter cam fitted but with the OE Hydraulic tappets so they tend to rattle a bit on start up or tickover.
Loads of Rocker covers got dumped on the market a few years ago so I'd want to know what the engine code was before I bought that car based on the engine
I actually like the wheels too
Mantzel did a 4.0 liter version too
bstardchild
Oh and they got an uprated gearbox (both Auto and Manual) and they have a reputation for breaking them too
Agreed. It looks quite low and an LSD is a sensible swap if not already in there. A few extra horses must make a world of difference but it's not a GSE so not one for my collection. Not sure what the deal is with those strut tops but if they're loose it would just fall off the road. The turret repairs aren't the nicest to look at but if they are strong then it's not a problem. I've seen worse patches, and bigger. As I said, I'd pull the motor for something else and drop a 12v back in there. That said, I'd like to explore horse increasology on a 12v before going down the "easy" route. Sent from still on my honeymoon using proboards The turrets are a real soft spots on these cars, i've seen people welding in thicker metal on top like you see in the picture, to toughen up that general area.
