Apr 18, 2015 21:55:21 GMT
A little bit of history first - back in the late 90s I bought my first car. An ageing Hyundai Stellar was not the usual choice for most 18 year olds, but the advert caught my eye as my Dad had owned one some years previously. Went to have a look at it, and the rest is history! After clocking up over 100k miles in 5 years (and now approaching 200k), it was getting rather tired and rusty so I took it off the road for a bit of work. Fast forwards to last year, and I finally got it on the road! I'll post up a few pictures from then, and hopefully if it's of interest will add some photos of the restoration later... Early morning in mid-Wales, on the way to an old mate's stag do last August just after completion (some of his friends remembered the car from Uni days!) Saved fuel on the return trip :-( Paintwork tatty, with mismatched panels - more on that later. Not entirely standard - Princess 4 pot calipers a tight squeeze under the original rims. I mentioned the bodywork; back in 2004/5 I found a mint donor car which supplied most of the bolt on panels. Last month I'd managed to save enough for a respray, so it was loaded on a trailer behind the trusty LT, and taken off for paint. Which brings us to where we are now; old paint has been flatted down and filled, but I've got them to weld new rear wheel arches in. They've found a panel with a very similar profile whcih they are going to adapt to suit, and after probably 100 hours welding on the shell (I'm now on my 4th welder!) I really fancied a break!
Last Edit: May 21, 2020 22:19:57 GMT by matfenwick
Sometimes, others may not understand why you like a car so much. Sometimes, you may not even understand why you like a car so much. But none of that matters; all that matters is that you like the car, and having it makes you happy.
pOG
SHATNER'S BASSOON
Apr 18, 2015 22:28:22 GMT
DEDICATION! Great car, nice work.
kevfromwales
the conrod's REALLY out the block now!
Apr 18, 2015 22:31:22 GMT
ZOMG! Is that birmingham garage in llanrwst???
If so you are VERY local to me!
Ace car, saw one in the wild in rhyl years back
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
Apr 18, 2015 22:42:46 GMT
That picture makes the car look a bit like the Maserati Bi-turbo thing - sure Maserati didn't just re-badge a Stellar??
Last Edit: Apr 18, 2015 22:45:05 GMT by ScotsDave
Apr 18, 2015 23:07:36 GMT
ZOMG! Is that birmingham garage in llanrwst??? If so you are VERY local to me! It is indeed! I'm just over the mountains in Blaenau Ffestiniog, but after visiting a couple of the bodyshops in Porthmadog and the one in Bala, they gave me the most confidence if not the cheapest price... The trip over wasn't the quickest journey, with 95 bhp to cope with 4 tons or so all-up weight over the Crimea pass. Heard a few Maserati comparisons; also Audi Ronal wheel copies? Although they are the originals - now fitted with brand new BFG tyres for the bargain sum of £19 each delivered!
Last Edit: Apr 18, 2015 23:13:40 GMT by matfenwick
qwerty
Club RR Member Number: 52
WOW can't actually remember the last time I saw a Stellar.
Kudos on the dedication and getting it all sorted. Will it be resprayed the original colour?
Apr 19, 2015 13:52:31 GMT
Close - I've gone for Aston Martin Silver Birch, which is subtly darker than the original silver. I think this will look better with the stainless trim. While it's away I've been doing stuff like tidying up the bonnet catch: I dipped that in Deox C to remove the rust, then zinc plated it: Not sure why, but most things I plate seem to come out quite dull, whatever current I go for. Still, looks a lot better than before! Also ready to go on are some nice new rear lights - the originals had gone brittle and started to craze slightly. I got these many years back - not sure Hyundai dealers would be able to get hold of them any more!
Apr 19, 2015 15:55:47 GMT
Is this the Hyundai model that shared a lot with the Cortina/Taunus chassis wise?
194? Willys Jeep MB 1965 Volvo 544 Special 1968 Opel Rekord 1975 Opel Kadett Estate 1985 Mercedes-Benz 230E 1985 Datsun 720 King Cab 4x4 diesel 1997 Volvo S70 2.5SE (ex. "Volvo544special65" - changed to more reader friendly username. )
Apr 19, 2015 20:51:47 GMT
Yes, the early 84-86 Stellars were very similar underneath - it's actually now got a Cortina rear axle in it. However, the propshaft drive flange is different which was a little bit of a stumbling block on a New Year's Eve when I did the swap some 15 years ago. Fortunately there was a propshaft centre within cyclable distance who could weld a new UJ on and balance it that day! Front suspension is identical in design although adjustable camber...had to get these bolts made for me as I cut through one of the originals during the strip down. The later Stellars used MacPherson struts at the front, and a slightly different axle with a Panhard rod.
Last Edit: Apr 19, 2015 20:55:22 GMT by matfenwick
düdo
wide as house
Not another Hyundai Stellar! This place should be called the 'Hyundai Stellar Owners Club' I'm looking at that fat exhaust thinking : either you is a closet chav or there's something that needs to breath under that unassuming facade? And before anyone else says it : Slam it! Now! Anyone who drives such a chariot gets three thumbs up from me!
That is superb, just superb...!!!
It has already been mentioned on here but this does indeed look very similar to some of the more blocky Masser saloons of the 1980's! Brilliant...!!!
I cannot wait to see more of this project, it looks wonderful...
***GARAGE CURRENTLY EMPTY***
Raoul Duke
Club RR Member Number: 117
Apr 20, 2015 17:41:41 GMT
I'm looking at that fat exhaust thinking : either you is a closet chav or there's something that needs to breath under that unassuming facade? Patience. It's worth the wait, trust me. Good to see you showing it off here, Mat
...a redder shade of neck on a whiter shade of trash...
Apr 20, 2015 17:56:57 GMT
I'm looking at that fat exhaust thinking : either you is a closet chav or there's something that needs to breath under that unassuming facade? Well spotted düdo (can I congratulate you on your fine collection of vehicles)...it may not be *entirely* standard under the skin. Here's a teaser from when I took it for its first MOT in 10 years, last summer:
düdo
wide as house
I cant believe that you've modified the last surviving Hyundai Stellar in Wales. The president of the owners club will be sending you a stiff letter soon!
Looks very tidy and interesting under there. I'm curious to know what other non-factory parts you've installed further forward.
( glad you like the collection - that means a lot coming from a Stellar driver)
Last Edit: Apr 21, 2015 9:06:57 GMT by düdo
Apr 21, 2015 19:41:32 GMT
I suppose there's not too many around any more - I checked How Many Left the other day: Someone is bound to guess what the engine is now...
Apr 21, 2015 19:56:37 GMT
I like where this is heading.
Click picture for more
Apr 22, 2015 21:28:15 GMT
OK, time for the full story! This is what lies under the bonnet... You may well ask why? And there's no real answer apart from the fact the original engine was tired after nearly 200k miles (half that in my ownership) and also looked a little lost in there. Someone suggested a V8 might fit, and the seed was sown... I'd never even done a straightforward engine change at that point nor owned a welder, but looking at it logically all I needed to do was get the engine and gearbox in roughly the right place, weld up some engine mounts and get a propshaft made to suit. How hard could it be? So I bought the engine in 2002 I think, and started my research. Looking around at what passed for the internet back then, at the turn of the century, I found people who'd done the same to Cortinas so it looked doable. Although with the new engine dangled above the engine bay it started to look a little more tricky. The front end of the crank just wouldn't clear the slam panel, even after I lost my rag and beat it with hammers. So I just cut it out (which I now regret) without thinking that simply by tilting the engine a lot, I'd have been able to get it in. There followed a bit of engine in and out shenanigans as I got it reasonably central. Cut 'n shut the sump to clear the crossmember, and made up cardboard templates for engine mounts which were then welded up. Engine went in around 2004, along with a fair bit of welding to the shell but then we moved house in 2005 and the project ground to a halt. The only other bits I managed to sort back then were the clutch actuation, and fitting an Audi 200 Turbo radiator underneath the slam panel. Which meant that even the shortest available water pump was still too long, so I shortened that to suit. The Stellar originally had a cable operated clutch, but there was no room in the engine bay for a clutch master cylinder. With a little bit of metalwork under the dash, I managed to put the master cylinder in facing the opposite way round, and welded an extension on the clutch pedal past the pivot to operate it. The original brake servo and master cylinder also fouled (but I can't remember on what), but one from a Mazda 323 was a good fit and also had a fluid take off for the clutch, although I only sorted out the lower end of the clutch hydraulics late 2013. The piston diameter was a guesstimated match for the new AP 4 pot calipers too so a good find! I did have a crack at building a manifold for the right bank, but I was never too happy with it. As I don't have a tube bender I cobbled it together with bits of bent tubing I had, and it sat very close to the steering UJ and upper wishbone bushes. But a lucky find (on here!) of some Rover P5B manifolds fitted better, although it was an epic job getting the old one off! The Audi radiator I had previously fitted had gone a little crumbly, but managed to find a decently priced brand new one in Denmark which I bought and fitted. As I had no room for an engine driven fan, I had to squeeze two electric ones between the front crossmember and radiator. I didn't know then whether they'd be up to the job, but figured they should be OK as they flow a huge amount for their size. They've been fine in keeping the temperature down in UK hot weather at least - the only issue being heat soak through the bulkhead! Another issue was the rev counter - it was reading twice as high as it should with obviously twice as many pulses per revolution. So I built a simple divide by two circuit, was was less than successful...anyone spot the problem? Even with a couple of protection diodes to limit the pulse spike to no more than + or - battery voltage it still didn't work, but then I did a little bit of research on the rev counter circuit. This turned out to be Lucas made, perhaps a legacy from when they assembled Cortinas under licence (Have a bonus photo of a Hyundai Cortina!) It seemed that if I connected a resistance of 48k ohms across a couple of terminals, it would work with the V8. Had to crudely make up the right resistance with what resistors I had, but nobody will see inside it! Happily, this works perfectly :-) I also managed to find a new Hyundai water temperature sender, which I fitted to the Rover manifold so the gauge reads correctly. By some stroke of luck, the M16 x 1.5 mm sender was a close enough match to the 5/8" UNF hole (only 0.1 mm different in both diameter and pitch) therefore screwed straight in! Similar story with the oil pressure sender, although I had to get a 240-33 ohm American spec. aftermarket part as Hyundai wanted £180 + VAT for a sender and I'd binned the one on the old engine. All wiring was extended where necessary using the original wiring loom colours for neatness, and mainly because I'm sad like that.
I got it on the road in August last year, and did around 1000 miles before gritting started in November. It's shamelessly going to be a fairweather car rather than a year round daily drive!
Apr 24, 2015 19:58:40 GMT
Progress at the bodyshop! Both wheel arches are in, although the passenger side needs the welds grinding back still. I can't believe what a good match they are for the original profile! That's going to save a lot of money compared to making a panel from scratch. Now looking at mid-May for completion. Hopefully. They've done me a deal where they work on the car during quiet periods (when they might otherwise be paying people to sit around) hence a good hourly rate - just have to hope they get a quiet period...
pOG
SHATNER'S BASSOON
Apr 24, 2015 21:25:59 GMT
Bloody hell! What a WINNER.
Apr 24, 2015 21:54:01 GMT
Nice to see where those manifolds ended up!
