andyborris
Apr 18, 2015 18:25:28 GMT
The light switch on my Triumph has become unreliable.
If I wire the switch so that the headlamps and sidelights operate together all the time, will pass it the MOT?
The on-line MOT manual doesn't say it will fail, but what's the opinions?
Thanks
Apr 18, 2015 21:02:07 GMT
that would be a fail, Side lights position light have to work independently (just asked a friend who is an mot tester that was his response)
scimjim
Club RR Member Number: 8
MOT sidelight questionscimjim
@scimjim
Club Retro Rides Member 8
Apr 18, 2015 21:43:08 GMT
Section 1.1 - position lamps (sidelights/parking lights) - must come on independently.
andyborris
Thanks, did read the on-line manual, but must've missed it!
Can you not refit a new light switch ?
froggy
Apr 21, 2015 10:42:54 GMT
A lot of modern stuff has a single switch position like fiat 500,s and boxer vans so they come on together with dipped beam
Apr 21, 2015 19:42:24 GMT
Canley classics should have the switch in stock.
Apr 21, 2015 19:45:36 GMT
A lot of modern stuff has a single switch position like fiat 500,s and boxer vans so they come on together with dipped beam Don't they still have a side light function on the switch so you can leave them on as parking lights?
froggy
Apr 22, 2015 12:47:34 GMT
I can't see where on the manual it says they have to work independently ,
MOT sidelight questionChasR
@chasr
Club Retro Rides Member 170
Apr 22, 2015 17:48:55 GMT
Alot of Mk1 Spares are now getting scarce, especially for the PI'd Mk1s where they are close to becoming none existant. This does of course make life trickier.
