Have my golf for sale. Its a 5 door 1986 1.8 4+E
Has few little bits of rust (filler cap and some small bits on the rear valance) only other bit I can see is a small bit at the bottom of the A pillar.
I'd describe it as fairly good for its age and other golfs I've owned have been much worse.
The body work has some blemishes here and there and some small bits of laquer peel.
I've clayed all of the paintwork as it had blue paint overpsray all over it. It needs a final cut and polish.
The interior is brown to say the least. Its retro though ha
It's in good order except for a little small bit of wear on drivers bolster a little bit of damage to thebdash board chrome trim and 6x9 holes in the parcel shelf that some moron has done.
The car starts runs and drives well. It needs a rear flexi hose for sure and a tyre or two will need replacing due to age.
It has no MOT but then again if I could be arsed I'd be asking for £500+ more.
The logbook will need applying for as that's gone missing.
As has any nhistory
Some good things though. Recently had all new locking set including ignition and boot.
I believe it has the weber manual carb. Picture included to confirm as I'm not 100% sure. Doesn't look like the pooburg however.
Not had the wheels off but I can see the front discs are vented which I believe are not standard (solid normally). No idea of what suspension is take it as if its standard.
Has a scorpion backbox not sure on the rest I've not looked.
Probably missed loads out. I'm no golf expert as you can tell.
It's for sale simply because I'm in and out of hospital so much and can't work on it.
I doubt it needs much to pass an MOT but I've no intention of doing it.
I just want my money back
Ive probably made it spound worse than it is. So come take a look.
Based in Wirral
£700 ono
May consider a swap for something on the road and interesting or quick. But i'd prefer cash cheers
More to follow when i get some better pics as the interior has been cleaned up somewhat now as has the body work. Also steering wheel lower cowling and dash are now on.
As has any nhistory
Based in Wirral
£700 ono
