andyborris
Mar 30, 2015 19:41:34 GMT
Need an alternator for the replacement BMW M52 engine in my Triumph.
2 types are listed, a 90 amp and a 140 amp.
I'm sure 90 amps will be enough, it's an old Triumph without all the modern electical gubbins, but the 140 amps type are quite a bit cheaper....what to do?
Will fitting a 140 amp alternator boil the battery or drain the hosepower?
Thanks
Rich
Club RR Member Number: 160
BMW 323 (E36) AlternatorRich
@foxmcintyre
Club Retro Rides Member 160
Mar 30, 2015 19:45:52 GMT
It'll be fine. It's a peak max output. As long as it physically fits it's not an issue to be over rated a bit.
BMW 323 (E36) AlternatorChasR
@chasr
Club Retro Rides Member 170
Mar 30, 2015 20:46:28 GMT
Indeedy. Do not forget that the fuel pump will take a hefty draw as well.
andyborris
Indeedy. Do not forget that the fuel pump will take a hefty draw as well. Good point, which I'd forgot about. Thought alternators only generate what's needed, but best to ask. Hope to restart the rewiring this weekend..........now where did I hide my MoJo?
