MOT: February 2016
Tax: Not transferrable
Mileage: 160,000
I bought this for my Mother 5 years ago, in 2010. Earlier this year I replaced it with a newer Mini, hence it's for sale. She's done less than 3k miles/year in it, however my Father is meticulous for mechanical things, so it's had:
Serviced every year (3,000 miles) (oil, filter, air filter, spark plugs)
Replacement engine with a known good s/h bottom end and cylinder head rebuilt.
Cambelt, tensioner, pulleys and waterpump done at the same time as above.
New clutch and cable
New gear linkage and rear bush for it
New brakes all round - Pagid discs and pads
New front lower arms and ARB links
New catalytic converter
New lambda sensor
There is no rust and everything works as it should.
Tyres are Toyo T1-R Proxes with 6mm tread front, 3mm rear
The only mods to the car are a stainless Mongoose exhaust (the original rusted away) and 15" Citroen C5 aluminium "steel" wheels (lightest 15" production wheel available), painted in white.
Price is £825. The car is on the Lincolnshire coast, close to Mablethorpe. Please PM me if you are interested and I will put you in contact with my Father.
Thanks,
Rob
Mileage: 160,000
New lambda sensor
Thanks,
Rob
