tuxman
Yes there are dust covers , I think you are right , itβs the only thing that can pull the pistonns back !! When I built them I lubed them with brake fluid , what would you suggest as a alternative ? Thanks .
tuxman
Did you fit new seals only, or pistons as well? What source?
Won't be the dust covers. Assembly with brake fluid should be fine, though most rebuild kits come with either red rubber grease or silicone grease for assembly.
We had a persistent issue just like this with some new (repro) Girling 16PB calipers. Pretty sure that was because the profile of the groove the seal sits in was wrong (certainly different to OE ones) - which won't be your problem - but what was interesting was how different seal kits changed their behavior. The ones they came with were quite soft - gave a very long pedal. OE Girling ones were dimensionally the same, but slightly harder compound. Hard pedal, brakes stayed on (& pistons very hard to get out again),whereas some pre-used and slightly compressed Girling OE ones nearly worked, but still tended to a slightly long pedal. Lube didn't seem to make alot of difference.
We could get them working for a while by removing the pads, pumping the pistons out a little then easing them back until the pads could just be worked in there. That would work for a few hundred miles until the pads wore down - they just would not self-adjust at the right point.
It was suggested that we pump the brakes on hard and wedge the pedal to hold it there overnight. Didn't work for us, but might be worth a try?
Nick
tuxman
I re used the old pistons , they looked in good order when all cleaned up !! The seal kits came from Questmead but were genuine AP Racing kits .
I have done as you suggested and pumped the brakes up the. Wedged them on hard !! I would say it has improved the situation !!!
Thanks for the advice !! Will let you know how I get on .
Thanks
All the right bits then. Hope wedging the pedal does the trick!
Nick
tuxman
My GSD today , made me chuckle watching her attack the hose pipe ππ Light relief with all the curse word going on !!
brake fluid works fine for assembly, i know thats what Ben at Godspeed Brakes uses.
tuxman
Another good day today !! New carbon dash panel fitted with repositioned gauges and for the first time ever air vent to blow hot or cold air onto our faces !!!! Only issue I have is the water is not flowing through the heater matrix , not sure why !! Any advice greatful !!
tuxman
Apr 22, 2020 15:24:43 GMT
Afternoon guys , how are we all doing ? Iβm staying extra safe at home due to the risk of Covid 19 !!! Thankfully I have plenty of time to work on the Noble ! Things are coming together nicely ππ Any damaged panels have been removed and filled/primes ect ready to be wrapped , gradually she is coming together . So exited ! Dawn has had her 50th birthday so itβs been a party weekend , plenty of prezzies as I owe her big !! I keep telling people she looks so good because she is married to a good man πππ Stay safe people ππ
Apr 22, 2020 22:01:56 GMT
Mate, we all know "Behind every great woman there's a great man"!!
Love her bike, same as yours?
tuxman
Apr 23, 2020 16:38:38 GMT
Mate, we all know "Behind every great woman there's a great man"!! Love her bike, same as yours? I keep telling her that ππππ Dawns bike is a Levo Carbon Comp so itβs a lot lighter than mine , trouble is she it getting too bloody fast πππ
tuxman
Apr 23, 2020 16:40:28 GMT
Apr 23, 2020 23:01:42 GMT
Wow, it's a real super car isn't it? I love it! But is your key not the same as I had when I had a 1993 Ford Fiesta? I always knew that the Fiesta was something special!!
jamesd1972
Club RR Member Number: 40
My Noble M12 jamesd1972
@jamesd1972
Club Retro Rides Member 40
Have you a bleed valve on the heater matrix ? Just a thought my old Skoda used to airlock -bit adrift as a comparator I know but the engine was behind me !
Keep the updates coming.
Stay safe & well
James
tuxman
tuxman
Apr 29, 2020 16:31:06 GMT
Another day hard at it , another day out my head on glue fumes ππππ Getting there though ππ
tuxman
Apr 30, 2020 18:31:17 GMT
So whatβs everybody up too The Noble has had to take a back seat as we have started decorating out lounge ..........I have only been promising to do it for 5 years ππππ I seemed to have got quite a lot of paint on me though ππ
Apr 30, 2020 22:35:05 GMT
Well, at least you've got your gloves on. At times like this proper PPE can't be ignored!
Abso-freakin-lootly beautiful work on the Noble. Top notch all around. Carpet looks grand, and that wrap! nicely done! are you better at the Noble than you are at painting? JP
