Mar 17, 2015 21:08:08 GMT
Hi there, have a quick question for the gurus here! About 3 months ago I bought a 1997 Volvo S70 2.5 turbo. Up until recently I have been using it daily without a single problem. Unfortunately about 2 weeks ago it cut out and refused to start. Disconnected the MAF sensor and it idled (a bit roughly) Purchased a new non genuine MAF hoping I might get lucky but no luck just same result. Swallowed the cost and ordered a genuine new Bosch part instead. Again exact same issue, car really struggled to start, idled very lumpy or cut out with also a very bad smell from what I'm guessing is the air/fuel mixture being right out. Was just hoping that I was just very unlucky and had another duff part. Sent that back for another replacement Bosch sensor. Tried it tonight and once again my problem is still there! Now it seems the previous owner has messed with the wiring at some point because the MAF plug on the cars side had at some point been cut off for some reason then reattached. I have checked the connections and they all seem ok, just to make sure I redone all the joints with insulated crimps and tested the plug for continuity, all seemed fine. Secondly, I have a warning light on the dash. Plugged my basic generic OBD scanner into it and got a P0103 fault back. Cleared the code but it instantly came back. I'm really at my wits end with this and not sure where to go from here! Any advice or tips would be great. Thanks guys
Dave
froggy
Mar 17, 2015 21:32:20 GMT
Have a close look at the throttle body , these are notorious and a good clean has fixed poor idle issues if the unit isn't faulty
Have a close look at the throttle body , these are notorious and a good clean has fixed poor idle issues if the unit isn't faulty Thanks for the tip, I'll give it a check and clean up tomorrow, see if that helps. Thanks pal
sounds like it could be a massive boost leak, check the rubber pipe connecting from the throttle body/boost pipe/idle control valve, it's notorious for splitting when it gets old.
Mar 21, 2015 15:50:35 GMT
Bit of an update, spent all day checking and re-checking. No leaks or splits in any pipes that I can see and I unplugged the ECU and tested the cabling from the MAF plug back. All seemed fine and continuity was good. Was about to give up and as a last resort I removed the IAC valve, cleaned it and also gave the throttle body a clean while I was down there. It just about started but once started idled fine. Took it for a good blast and went ok, doesn't quite pull quite as hard as before and I still got the P0103 error, I clear it and it just comes straight back. It also hesitates to start and won't start without a bit of throttle. Once started, idles fine and does not cut out or hunt around. So at the moment it's drivable and about 90% there. I just need to see why that error code keeps coming back and why it's a hard starter. Seems odd that cleaning the throttle body and IAC valve has nearly completely fixed it. Would it be worth replacing these parts?
froggy
Mar 22, 2015 11:09:03 GMT
Check the diagphram in the re circ valve on the turbo for splits but that shouldn't affect light throttle running as its still metering the air . Fuel filter ok?
